| » Maytag Neptune MAH5500BWQ door latch and another question... |
Model Number: MAH5500BWQ Brand: Maytag Age: 5 - 10 years
Yesterday we started having trouble in that the washer wouldn't run any cycles. After messing with it a bit I discovered the "FL" error code. Some Google work helped me figure out this is most likely the latch assembly or the control module (please correct me if I'm wrong).
Suddenly everything started working again so I ran a load and when I checked on it later it had stopped (showed 15 minutes left, if I remember correctly). I don't remember the exact code but I remember it being failure to unlock rather than failure to lock. There was also water leaking from the machine. The door *was* unlocked and when I opened the door it was full of water which ran out of the door. I quickly pulled out the laundry and that lowered the water to below the threshold of the door. I mopped up a bit and went to bed (it was after midnight by then) leaving water in the machine. I assumed that if the door wasn't fully latched that it might have loosened enough that the water was leaking around the door. I also shut off and unplugged the washer. This morning I saw that there was still water leaking out and that the water level inside the washer was lower. I plugged it back in and it again acted normal so I ran a spin cycle to get the remaining water out. With all that being said - my question is: Is it likely this water leaking was a result of the cycle being interrupted and being unplugged and if I repair the latch problem I'll be OK or am I likely to have another problem that may need attention and more money? Please let me know if you need any more information. Thanks, Randy In case it matters the serial number is B241045OEV Ads By Google Related Models Last edited by RandyP1234 : 09-09-2012 at 09:35 AM. Reason: Added S/N |
| Display Modes | |
| maytag neptune door latch problem | duke098 | Washer Repair | 2 | 12-02-2011 05:03 PM |
| Door latch for front load Maytag Neptune | Paul F | Washer Repair | 0 | 10-13-2011 01:47 PM |
| Neptune Door Latch | sitej11 | Washer Repair | 3 | 05-01-2010 04:53 PM |
| Door latch spring question | Zealtrax | Dryer Repair | 1 | 02-26-2010 09:39 PM |
| Maytag Neptune front loader part question | buckley.l | Washer Repair | 2 | 04-02-2009 03:53 PM |
