Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Whirpool Washer Will No Go To Rinse Cycle (http://forum.appliancepartspros.com/washer-repair/499401-whirpool-washer-will-no-go-rinse-cycle.html)
roperstopper 09-07-2012 08:07 AM
I have a roper/whirlpool 4 cycle washer.It works great through all wash cycles,fills-aggitates,drains and spins,but will not start the rinse cycle on any of the wash options.Does not begin to fill,etc. Timer is silent-no noise-no nada.
thanks
Simon / APP Team 09-07-2012 09:18 AM
Hi.
Most likely the rinse cycle is set for cold water only. Check if you are getting cold water to the washer, then check the water valve. If it's getting 120VAC to the solenoid - replace it Part number: 285805
Part number: 285805
Here are the breakdown diagrams and Replacement parts for Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE | AppliancePartsPros.com
Post the results.
Simon.
roperstopper 09-08-2012 12:59 PM
Thanks I'll Check Into It
ancel1961 09-09-2012 01:05 PM
Roper washer won't advance to rinse cycle
Thanks Simon / APP Team,
You gave me the solution to the problem I was having with my washer
You took a load off my shoulders
Take care ;)
Simon / APP Team 09-10-2012 09:54 AM
You are welcome.
Simon.
