Discuss
Washer UL HELP
 in
Washer Repair
My Kenmore Elite Oasis top load washer is banging then says UL while in the last 6-8 minutes of the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer UL HELP
  #1 (permalink)
Old 09-04-2012, 02:19 PM
Junior Member
dianaMo is on a distinguished road
Default Washer UL HELP
Model Number: 11027087603   Brand: Kenmore   Age: 1 - 5 years
My Kenmore Elite Oasis top load washer is banging then says UL while in the last 6-8 minutes of the cycle. Even after adjusting clothes it still does it. It will not do it if washer is empty. Spins just fine. We removed the inner tub and noticed water sounds between the walls of the tub. (not sure if that is normal) My husband says he thinks the tub has a crack and water level is not level in tub and is causing UL while spinning, I say we need new suspension rods.
Ads By Google
Related Models
Kenmore 11027087603 RESIDENTIAL WASHER
Kenmore 11027087604 RESIDENTIAL WASHER
Kenmore 11027087605 RESIDENTIAL WASHER
Kenmore 11027092600 WASHER
Kenmore 11027092601 RESIDENTIAL WASHER
Kenmore 11027092602 RESIDENTIAL WASHER
Kenmore 11027092603 RESIDENTIAL WASHER
Kenmore 11027112600 WASHER
Kenmore 11027152600 AUTOMATIC WASHER
Kenmore 11027152601 RESIDENTIAL WASHER
Kenmore 11027152602 RESIDENTIAL WASHER
Kenmore 11027172600 WASHER
Kenmore 11027222600 RESIDENTIAL WASHERS
Kenmore 11027224600 RESIDENTIAL WASHERS
Kenmore 11027272600 WASHER
Kenmore 11027322600 RESIDENTIAL WASHERS
Kenmore 11027332600 RESIDENTIAL WASHERS
Kenmore 11027342600 RESIDENTIAL WASHERS
Kenmore 11027422600 RESIDENTIAL WASHERS
Kenmore 11027432600 RESIDENTIAL WASHERS
Kenmore 11027442600 RESIDENTIAL WASHER
Kenmore 11027522600 RESIDENTIAL WASHERS
Kenmore 11027532600 RESIDENTIAL WASHERS
Kenmore 11027542600 RESIDENTIAL WASHER
Kenmore 11027612600 RESIDENTIAL WASHERS
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Kenmore 11027632600 RESIDENTIAL WASHERS
Kenmore 11027642600 RESIDENTIAL WASHERS
Kenmore 11027721600 RESIDENTIAL WASHER
Kenmore 11027731600 RESIDENTIAL WASHERS
Kenmore 11027741600 RESIDENTIAL WASHERS
Kenmore 11027751700 RESIDENTIAL WASHER
Kenmore 11027761700 RESIDENTIAL WASHER
Kenmore 11027782700 RESIDENTIAL WASHER
Kenmore 11027802690 AUTOMATIC WASHER
Kenmore 11027802691 AUTOMATIC WASHER
Kenmore 11027812690 AUTOMATIC WASHER
Kenmore 11027812691 AUTOMATIC WASHER
Kenmore 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
Kenmore 11027824790 AUTOMATIC WASHER
Kenmore 11027831600 RESIDENTIAL WASHER
Kenmore 11027841600 RESIDENTIAL WASHERS
Kenmore 11027852790 AUTOMATIC WASHER
Kenmore 11027852791 AUTOMATIC WASHER
Kenmore 11027862790 AUTOMATIC WASHER
Kenmore 11027871600 RESIDENTIAL WASHERS
Kenmore 11027872600 RESIDENTIAL WASHERS
Kenmore 11027874600 RESIDENTIAL WASHERS
Kenmore 11027892790 AUTOMATIC WASHER
Kenmore 11027892791 AUTOMATIC WASHER
Kenmore 11027894790 AUTOMATIC WASHER
Kenmore 11027894791 AUTOMATIC WASHER
Kenmore 11027902790 AUTOMATIC WASHER
Kenmore 11027982790 AUTOMATIC WASHER
Kenmore 11028002010 AUTOMATIC WASHER
Kenmore 11028002011 AUTOMATIC WASHER
Kenmore 11028012010 AUTOMATIC WASHER
Kenmore 11028012011 AUTOMATIC WASHER
Kenmore 11028032700 RESIDENTIAL WASHER
Kenmore 11028032701 RESIDENTIAL WASHER
Kenmore 11028042700 RESIDENTIAL WASHER
Kenmore 11028042701 WASHER
Kenmore 11028062800 RESIDENTIAL WASHER
Kenmore 11028072800 RESIDENTIAL WASHER
Kenmore 11028081700 WASHER
Kenmore 11028082700 RESIDENTIAL WASHER
Kenmore 11028087700 RESIDENTIAL WASHER
Kenmore 11028091700 WASHER
Kenmore 11028092700 RESIDENTIAL WASHER
Kenmore 11028097700 WASHER
Kenmore 11028222700 RESIDENTIAL WASHER
Kenmore 11028222701 WASHER
Kenmore 11028299890 AUTOMATIC WASHER
Kenmore 11028322700 RESIDENTIAL WASHER
Kenmore 11028332700 RESIDENTIAL WASHER
Kenmore 11028352700 RESIDENTIAL WASHER
Kenmore 11028362700 RESIDENTIAL WASHER
Kenmore 11028372700 RESIDENTIAL WASHER
Kenmore 11028422700 RESIDENTIAL WASHER
Kenmore 11028432700 RESIDENTIAL WASHER
Kenmore 11028522700 RESIDENTIAL WASHER
Kenmore 11028522701 RESIDENTIAL WASHER
Kenmore 11028532700 RESIDENTIAL WASHER
Kenmore 11028532701 RESIDENTIAL WASHER
Kenmore 11028622700 RESIDENTIAL WASHER
Kenmore 11028622701 RESIDENTIAL WASHER
Kenmore 11028632700 RESIDENTIAL WASHER
Kenmore 11028632701 RESIDENTIAL WASHER
Kenmore 11028692700 RESIDENTIAL WASHER
Kenmore 11028692701 RESIDENTIAL WASHER
Kenmore 1102870090 AUTOMATIC WASHER
Kenmore 11028722700 RESIDENTIAL WASHER
Kenmore 11028732700 RESIDENTIAL WASHER
Kenmore 11028752700 RESIDENTIAL WASHER
Kenmore 11028762700 RESIDENTIAL WASHER
Kenmore 11028782700 RESIDENTIAL WASHER
Kenmore 11028802890 AUTOMATIC WASHER
Kenmore 11028803890 AUTOMATIC WASHER
Kenmore 11028812790 AUTOMATIC WASHER
Kenmore 11028822790 AUTOMATIC WASHER
Kenmore 11028822791 AUTOMATIC WASHER
Kenmore 11028824790 AUTOMATIC WASHER
Kenmore 11028824791 AUTOMATIC WASHER
Kenmore 11028832700 RESIDENTIAL WASHER
Kenmore 11028837700 RESIDENTIAL WASHER
Kenmore 11028842700 RESIDENTIAL WASHER
Kenmore 11028847700 RESIDENTIAL WASHER
Kenmore 11028872890 AUTOMATIC WASHER
Kenmore 11028872891 AUTOMATIC WASHER
Kenmore 11028874890 AUTOMATIC WASHER
Kenmore 11028874891 AUTOMATIC WASHER
Kenmore 11028882790 AUTOMATIC WASHER
Kenmore 11028882791 AUTOMATIC WASHER
Kenmore 11028884790 AUTOMATIC WASHER
Kenmore 11028884791 AUTOMATIC WASHER
Kenmore 11028892790 AUTOMATIC WASHER
Kenmore 11028892791 AUTOMATIC WASHER
Kenmore 11028894790 AUTOMATIC WASHER
  #2 (permalink)
Old 09-04-2012, 04:39 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Most likely this is what you need to replace
Part number: W10189077
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-30-2012, 09:05 AM
Junior Member
stpjokin1996 is on a distinguished road
Default
I know this message is old, but I was wondering if the suspension rods fixed your issue. My washer is having the same issue currently. I can't decide if its the rods or a bad balance sensor.
If you are still reading that's for responding.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
