| » Maytag Neptune Error 3E (not E3) |
Model Number: MAH9700AWW Brand: Maytag Age: 5 - 10 years
Hello,
I am having a recurring issue with a washer. Here are the details: Maytag Neptune Washer Model: **MAH9700AWW Serial #: **10966890GG Dated: **April 2005 Error Code 3E (not E3): - Displayed on digital readout - Code almost always happens after several successive loads (almost never on 1st load) - Can happen during rinse or spin cycle - Drum tries to spin several times (starts & moves slightly) then finally displays error code - Solutions to clear error and proceed (tried in order): ** **1. Restarting by pressing Dial (sometimes clears and proceeds on 1st try) ** **2. Opening door and shifting clothes then Restarting ** **3. Waiting significant amount of time before Restarting ** **4. Turn off washer and start rinse or spin cycle manually - Cycling power does not seem to have any effect - Will sometimes run for several minutes before entering error code 3E again. **At that point, time remaining on cycle when it starts up again does not account for time it ran between error codes - Seems to be independent of size and positioning of load - Had some weight (cat litter bags on top of washer) to dampen vibration. **When these were removed, frequency of error code seemed to slow. - Wiring and connections all look correct Potential causes and solutions I have seen: - Loose connections - Control Board (info on 2 labels below) ** **=> 06FMWDP2702 BHCEY6G0092 ** **=> 20050617 C 0394 MWDP27-02Y310 - Hall Effect Sensor on motor (requires new motor + sensor) I am planning to purchase a new control board but am unsure of the correct part as well as if a new sensor is needed with the control board. Thank you. Ads By Google Related Models |
| Display Modes | |
| Maytag neptune error code | brockner75 | Washer Repair | 2 | 02-12-2012 04:20 PM |
| Maytag Neptune 3E error | john.nell | Washer Repair | 0 | 02-08-2011 07:52 AM |
| maytag neptune - nd error | Rich Gassett | Washer Repair | 9 | 10-16-2010 12:36 PM |
| Maytag Neptune error code: L5 or E5 | skalesplitur | Washer Repair | 1 | 03-05-2010 06:46 AM |
| Maytag Neptune Thermistor Error | P69firebrd | Washer Repair | 1 | 01-24-2010 01:18 PM |
