Discuss
Grease under washer--advice?
 in
Washer Repair
There is grease under my 15+ year old washing machine, and I'm having trouble figuring out the source. I noticed
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Grease under washer--advice?
  #1 (permalink)
Old 09-02-2012, 07:05 PM
Junior Member
Newbie2 is on a distinguished road
Default Grease under washer--advice?
Model Number: WWA7050GAL   Brand: GE   Age: More than 10 years
There is grease under my 15+ year old washing machine, and I'm having trouble figuring out the source. I noticed the grease near a front corner when I run a load, so after trying to deny what I was seeing for several weeks, I've unhooked everything and pulled the washer away from the wall, and the entire floor underneath was covered in greasy oily gook. (It's been 12 long years since the washer's been moved.)
I cleaned up the mess, and took the back panel board off to investigate, because it doesn't seem possible to take the front-and-sides cabinet piece off without disassembling the entire washer. I haven't run it yet with the back off to try to see what's leaking, as I've read suggested in other threads. When I do this, I assume I should have the water hooked up like normal, right?
All of the hoses are firmly attached, I don't think there's a water leak (if there is, it's still small), and the greasiest parts of the interior were the interior of the metal piece that sits diagonally and seems to provide the main platform for the transmission and the tub assembly. Some of the interior looks like grease is spraying around the inside of the cabinet while it runs.
I'm looking for thoughts on how to diagnose the problem, thoughts on what part(s) I'm going to need to replace, and directions about how to disassemble and reassemble this thing.
I recently repaired its companion dryer, and with that success, I'd really rather fix this one too, as opposed to buying something new. Any assistance is gratefully received. Thanks!
Related Models
General Electric WWA7050GAL Washer
General Electric WWA7050GBL Washer
General Electric WWA7059VCL Washer
General Electric WWA7060VCL Washer
General Electric WWA7070BAL Washer
General Electric WWA7070GAL Washer
General Electric WWA7070GBL Washer
General Electric WWA7070VCL Washer
General Electric WWA7079VCL Washer
General Electric WWA7304PML Washer
General Electric WWA7304VKL Washer
General Electric WWA7304VLL Washer
General Electric WWA7600RBL Washer
General Electric WWA7600SALAA Washer
General Electric WWA7600SALWW Washer
General Electric WWA7600SBLAA Washer
General Electric WWA7600SBLWW Washer
General Electric WWA7619MAL Washer
General Electric WWA7640SALAA Washer
General Electric WWA7640SALWW Washer
General Electric WWA7640SBLAA Washer
General Electric WWA7640SBLWW Washer
General Electric WWA7646MAL Washer
General Electric WWA7650SALAA Washer
General Electric WWA7650SALWW Washer
General Electric WWA7650SBLAA Washer
General Electric WWA7650SBLWW Washer
General Electric WWA7678MAL Washer
General Electric WWA7680SALAA Washer
General Electric WWA7680SALWW Washer
General Electric WWA7680SBLAA Washer
General Electric WWA7680SBLWW Washer
General Electric WWA7690SALAA Washer
General Electric WWA7690SALWW Washer
General Electric WWA7690SBLAA Washer
General Electric WWA7690SBLWW Washer
General Electric WWA7800MAL Washer
General Electric WWA7800RBL Washer
General Electric WWA7826MAL Washer
General Electric WWA8062BAL Washer
General Electric WWA8062VEL Washer
General Electric WWA8072BAL Washer
General Electric WWA8072GAL Washer
General Electric WWA8072VEL Washer
General Electric WWA8300BAL Washer
General Electric WWA8300GAL Washer
General Electric WWA8300GBL Washer
General Electric WWA8300VCL Washer
General Electric WWA8301MAL Washer
General Electric WWA8306LAL Washer
General Electric WWA8306LBL Washer
General Electric WWA8307LAL Washer
General Electric WWA8307LBL Washer
General Electric WWA8310BAL Washer
General Electric WWA8310GAL Washer
General Electric WWA8310GBL Washer
General Electric WWA8314PML Washer
General Electric WWA8314VKL Washer
General Electric WWA8314VLL Washer
General Electric WWA8318LAL Washer
General Electric WWA8318LBL Washer
General Electric WWA8319VCL Washer
General Electric WWA8320BAL Washer
General Electric WWA8320GAL Washer
General Electric WWA8320GBL Washer
General Electric WWA8320VCL Washer
General Electric WWA8324BAL Washer
General Electric WWA8324GAL Washer
General Electric WWA8324GBL Washer
General Electric WWA8326LAL Washer
General Electric WWA8326LBL Washer
General Electric WWA8330BAL Washer
General Electric WWA8330GAL Washer
General Electric WWA8330GBL Washer
General Electric WWA8340BAL Washer
General Electric WWA8340GAL Washer
General Electric WWA8340GBL Washer
General Electric WWA8340VCL Washer
General Electric WWA8344BAL Washer
General Electric WWA8344VCL Washer
General Electric WWA8344VKL Washer
General Electric WWA8344VLL Washer
General Electric WWA8350BAL Washer
General Electric WWA8350GAL Washer
General Electric WWA8350GBL Washer
General Electric WWA8354VLL Washer
General Electric WWA8354VML Washer
General Electric WWA8354VNL Washer
General Electric WWA8355BAL Washer
General Electric WWA8355GAL Washer
General Electric WWA8359VCL Washer
General Electric WWA8360BAL Washer
General Electric WWA8360GAL Washer
General Electric WWA8360GBL Washer
General Electric WWA8364VKL Washer
General Electric WWA8364VLL Washer
General Electric WWA8366LAL Washer
General Electric WWA8366LBL Washer
General Electric WWA8480BAL Washer
General Electric WWA8480GAL Washer
General Electric WWA8500GAL Washer
General Electric WWA8500GBL Washer
General Electric WWA8500GCL Washer
General Electric WWA8600GAL Washer
General Electric WWA8600GBL Washer
General Electric WWA8600GCL Washer
General Electric WWA8600RBL AUTOMATIC WASHER
General Electric WWA8600RBLAA Washer
General Electric WWA8600RBLWW Washer
General Electric WWA8600SALAA Washer
General Electric WWA8600SALWW Washer
General Electric WWA8600SBLAA Washer
General Electric WWA8600SBLWW Washer
General Electric WWA8600SCLAA Washer
General Electric WWA8600SCLWW Washer
General Electric WWA8606MAL Washer
General Electric WWA8607SALAA Washer
General Electric WWA8607SALWW Washer
General Electric WWA8607SBLAA Washer
General Electric WWA8607SBLWW Washer
  #2 (permalink)
Old 09-02-2012, 09:49 PM
Junior Member
Default More info
I cleaned out the inside of the machine as much as I could, hooked the water back up and ran it on a small cold cycle, watching for any drips. There were none. After it was all done, I ran a paper towel around the bottom of the motor, and other parts that had previous been quite greasy and dirty, and there was nothing that appeared to be fresh oil. I'm letting it sit overnight and will check later to see if there are any new oil spots on the floor.
Is it possible that there is an infinitesimal spray of oil every time the washer runs, and what I finally noticed was the accumulation of 12 years of that?
  #3 (permalink)
Old 09-03-2012, 08:43 PM
Junior Member
Unhappy The next day
Just before going to bed last night, I checked under the washer and there was one fresh drop of oil. This morning the drop was bigger, like one more drip had accumulated in the same spot. By later in the day, there was another small drip about 4-5 inches away from the first two.
I cleaned those drops up, and with a paper towel I checked to see if I could tell where they came from. The pump is situated below the tub, and under the pump is the wheel that drives the belt that spins the inner tub, and under the wheel and belt is the motor. There are a couple of screws under the wheel housing that I think attach it to the suspension assembly. Those screws were where the fresh oil was found.
This model seems like it's put together in a rather inaccessible way, so I really need some help figuring out what I need to fix and how to take it apart in a way that I can put it all back together again. Thanks for any thoughts!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer getting grease on clothes joanneg Washer Repair 2 02-24-2012 10:42 AM
Grease or oil in washer tub? fixedyet? Washer Repair 2 04-21-2010 05:06 PM
Grease for Whirlpool washer kit 285587 rockindiver Washer Repair 1 08-11-2009 03:15 PM
grease/scum in washer after cycle gr8hands Washer Repair 1 06-22-2009 05:03 PM
