DennisBarrineau
#1 Posted : Saturday, September 1, 2012 10:43:36 AM(UTC)
DennisBarrineau
Recently had the machine stop spinning and agitating at all, the motor is not doing anything, however the water is pumping out and filling properly. Just replaced the motor inverter and it worked for two loads and back to the same problem, The Led lights on the board of the MOtor inverter is flashing 7 times in red. What can be my problem ??
sidfink43
#2 Posted : Monday, September 3, 2012 5:05:27 PM(UTC)
sidfink43
These machines with the mode shifter are really hard to diagnose. Here is what the code 7 means.
"7 flashes - This code will prevent the motor from operating. This means that you washed clothes four times and the lid switch never opened. Since you can’t wash clothes four times without opening the lid there is a problem. This can be that the motor is flagging this error code for no apparent reason or the lid switch is bad. There are instructions on how to test the lid switch below and if it fails the test replace it. If however the lid switch is ok clear the code as described below and if it continues to flag this code replace the motor."
The first thing to do on these models is to reset it, then if that doesn't things check the lid switch and its wiring.
"To clear the error code, turn the washer off. Then disconnect power for about 20 seconds. Next, reconnect power then open and close the lid five or more times within 12 seconds in the first 30 seconds of power-up. "
Whirlpool washing machine not spinning properly (Washer Repair)
by Guest 6/9/2021 9:12:59 PM(UTC)
Kenmore washing machine not spinning without help (Washer Repair)
by narcsisuss 7/6/2015 5:54:17 AM(UTC)
Washing Machine not spinning (Washer Repair)
by Eigenbrod 6/10/2013 4:53:56 AM(UTC)
GE Washing Machine not spinning consistently (Washer Repair)
by Rjr19146 11/5/2012 6:15:45 AM(UTC)
Washing machine not spinning (Washer Repair)
by jjlittle.64 8/27/2012 10:29:37 PM(UTC)
washing machine not spinning (Washer Repair)
by tessjones 6/12/2010 1:19:26 PM(UTC)
by jennyl11 11/20/2009 11:38:31 PM(UTC)
Frigidaire Top Loading Washing Machine not Spinning (Washer Repair)
by truett 6/27/2009 10:12:24 AM(UTC)
Kenmore washing machine not spinning (Washer Repair)
by Jim Bender 5/6/2009 7:48:20 AM(UTC)
