Discuss
Cloths washer rotory switch
 in
Washer Repair
On this machine there is a center knob which you push in to engage the washing cycle rotery switch and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Cloths washer rotory switch
  #1 (permalink)
Old 09-22-2009, 12:03 PM
Martn Mieger Martn Mieger is offline
Junior Member
Martn Mieger is on a distinguished road
Default Cloths washer rotory switch
Model Number: LST9355BNO   Brand: Whirlpool   Age: More than 10 years
On this machine there is a center knob which you push in to engage the washing cycle rotery switch and pull out to start the cycle. The knob no longer engages the rotery switch. The knob threads are not damaged and the dial behind the knob still moves the rotery switch.All of the electrical functions work properly. Where is the clutch that the knob is supposed to engage located? Is it between the knob and dial or is it in the rotery switch? This will help me to know which parts to order to fix this. This has been a totally trouble free machine untell this problem.Thanks Martin
Related Models
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
Whirlpool LSV5132AG0
Whirlpool LSV5132AN0
Whirlpool LSV5132AW0
Whirlpool LSV6233AG0
Whirlpool LSV6233AN0
Whirlpool LSV6233AW0
Whirlpool LSV6234AN0
Whirlpool LSV6234AW0
Whirlpool LSV7233BG0
Whirlpool LSV7233BN0
Whirlpool LSV7233BQ0
Whirlpool LSV7233BW0
Whirlpool LSV7233DQ0
Whirlpool LSV7233DZ0
Whirlpool LSV7244AN0
Whirlpool LSV7244AQ0
Whirlpool LSV7244AW0
Whirlpool LSV7245AN0
Whirlpool LSV7245AQ0
Whirlpool LSV7245AW0
Whirlpool LSV8244BN0
Whirlpool LSV8244BQ0
Whirlpool LSV8244BW0
Whirlpool LSV8244DQ0
Whirlpool LSV8244DZ0
Whirlpool LSV8245AN0
Whirlpool LSV8245AW0
Whirlpool LSV9244DQ0
Whirlpool LSV9244DZ0
Whirlpool LSV9245BN0
Whirlpool LSV9245BW0
Whirlpool LSV9355AN0
Whirlpool LSV9355AW0
Whirlpool LSV9355BN0
Whirlpool LSV9355BW0
Maytag LSW24A Ref - SXS/I&W
Whirlpool LSW9245EQ0
Whirlpool LSW9245EQ1
Whirlpool LSW9245EQ2
Whirlpool LSW9700PQ0 Automatic Washer
Whirlpool LSW9700PQ1 Automatic Washer
Whirlpool LSW9700PQ2 Automatic Washer
Whirlpool LSW9750PW0 Automatic Washer
Whirlpool LSW9750PW1 Automatic Washer
Whirlpool LSW9750PW2 Automatic Washer
Whirlpool LSW9750PW3 Automatic Washer
Frigidaire LT150EXD2 Wwh(v1) / Tumble Action Washer
Frigidaire LT150EXF2 Wwh(v2) / Tumble Action Washer
Frigidaire LT150EXH2 Wwh(v3) / Tumble Action Washer
Frigidaire LT150EXV2 Wwh(v4) / Tumble Action Washer
Frigidaire LT150EXW2 Wwh(v5) / Tumble Action Washer
Frigidaire LT150JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT150JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT150JXW1 Wwh(v5) / Tumble Action Washer
Frigidaire LT150LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150LXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT200PXD2 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT200PXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXW2 Wwh(v1) / 27 " Front Load Washer
Frigidaire LT250EXD2 Wwh(v6) / Tumble Action Washer
Frigidaire LT250EXD4 Wwh(v7) / Tumble Action Washer
Frigidaire LT250EXF2 Wwh(v8) / Tumble Action Washer
Frigidaire LT250EXF4 Wwh(v9) / Tumble Action Washer
Frigidaire LT250EXH2 Wwh(v10) / Tumble Action Washer
Frigidaire LT250EXH4 Wwh(v11) / Tumble Action Washer
Frigidaire LT250EXV2 Wwh(v12) / Tumble Action Washer
Frigidaire LT250EXV4 Wwh(v13) / Tumble Action Washer
Frigidaire LT250EXW2 Wwh(v14) / Tumble Action Washer
Frigidaire LT250EXW4 Wwh(v15) / Tumble Action Washer
Frigidaire LT250JXD1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250JXF1 Wwh(v7) / Tumble Action Washer
Frigidaire LT250JXH1 Wwh(v8) / Tumble Action Washer
Frigidaire LT250JXV1 Wwh(v9) / Tumble Action Washer
Frigidaire LT250JXW1 Wwh(v10) / Tumble Action Washer
Frigidaire LT250LXD1 Wwh(v5) / Tumble Action Washer
Frigidaire LT250LXH1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250LXW1 Wwh(v4) / Tumble Action Washer
Frigidaire LT350RXD1 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT350RXW1 Wwh(v1) / 27 " Front Load Washer
Whirlpool LT4900XMW0
Whirlpool LT4900XMW1
Whirlpool LT4900XMW2
Whirlpool LT4900XSW1
Whirlpool LT4900XSW2
Whirlpool LT4900XSW3
Whirlpool LT4905XMW0
Whirlpool LT5000XLW0
Whirlpool LT5000XMW0
Whirlpool LT5000XMW1
Whirlpool LT5000XSW1
Whirlpool LT5000XSW2
Whirlpool LT5000XSW3
Whirlpool LT5000XVN0
Whirlpool LT5000XVW0
Whirlpool LT5004XMW0
  #2 (permalink)
Old 09-23-2009, 11:02 AM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Hi Martin
It may be that the timer has come loose from its moorings. Take out the two screws that hold the console to the cabinet and see if it is loose.
You may need a new timer, which unfortunately for your machine is rather expensive.
Here is the part
Part number: AP3018716
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer spins one way also leaves cloths wet Broker Dave Washer Repair 5 01-18-2009 03:39 AM
Need help with Amana cloths washer stevekll Washer Repair 0 07-12-2008 04:34 PM
Washer intermitantly leaves cloths wet james King Washer Repair 1 02-26-2008 05:31 AM
Washer intermitantly leaves cloths wet james King Washer Repair 0 11-30-2007 01:29 PM
Need clean cloths, whirpool washer smurzynski Washer Repair 1 08-06-2007 05:50 PM
