Washer spins but won't extract water-is the pump bad? Thanks
Look for restricted or kinked drain hose. Also could be an obstruction in the pump.
Originally Posted by: magician59 Look for restricted or kinked drain hose. Also could be an obstruction in the pump. Thank you-There was an obstruction in the pump-I removed it and put it back together and macine works fine= Thanks .
Well done! Just saved yourself a couple C notes in service call and labor.
