AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Top Loader Direct Drive: Won't agitate/spin - Coupler OK but not moving
Kenmore top-loader direct-drive. Stopped agitating/spinning but would pump out water. But coupler looks A-OK and turns fine by hand. Strange thing is... as a test, I observed it during the agitate portion of the cycle and the coupler isn't even turning. The motor is running and I can see it turning the connection into the pump - which seems odd to me since a) I wouldn't think the pump side should be doing anything during the agitate cycle but b) regardless, it isn't actually pumping out the water. It is however making a very loud noise coming from that area around the motor/pump. So, I'm a bit baffled why the motor is running but not turning the coupler.
Controller gone bad and sending the wrong signal to the motor? This is the only thing I can think of (not to mention that it's been flaky for years in that we had to quit using the hot water setting because it stopped going into the rinse cycle). So, maybe it's lost some more of its mind??? Any ideas would be appreciated. If it helps, I have a multi-meter and, although no expert, can take readings if given instructions. Thanks in advance for any help you can offer.
P.S. - I realize it's an old machine and the easy answer would be to just replace it but now is just not the time.
Follow-up to my own post in case it helps someone else. Do not assume that just because the coupler has no outward appearance of being broken that there's nothing wrong with it. It turns out that the original version of these plastic couplers were 100% plastic (the new ones have a metal insert) and the inner core of plastic can strip out/hairline crack/etc. resulting in the motor shaft just free-spinning inside it. So, even if looks OK from the outside, go ahead and take off the motor and completely examine it from the inside. That was the problem with mine. Now, if anyone has any idea about the unrelated problem (which started a few years ago) of why the washer stopped going into the rinse cycle but only when using hot water, please post. Thanks!
Washer Repair
