When we put the washer on normal it starts to fill with water and then later you will hear it beeping and it will show OE on control panel. What does this mean? I have change cycles to just spin and it will pump out the water and then lock the door and just set there. What is wrong is the motor bad? if so I do I remove and replace it?
