AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Affinity washer wont start/door lock light stays off
Please help...I replaced the door lock/switch (part#131763202)and washer still wont run eventhough I still hear relay clicking...the door strike is still good.Do I need to replace the Main Control Board unit?or what can I do?
Groups: APP Team
Hi. Check the connections at the door lock and the control board, check the wire harness. If everything OK - replace the control board Part number: 137006030
I disassembled washer and all connection are fine.I got an errror code"E41"and did the following test w/voltmeter on the door lock switch and the drain pump and unsure what voltage to make of....it didnt read 120v but it was not zero(0)...did not disassembled drain pump to check for any obstruction as test also suggest-not to sure that has anything to do with "door light"...checked drain hose-also clear.just trying to save $ without buying main Control Board...any mre suggestion will help a great deal...thnx
Groups: APP Team
Hi.
I'm afraid you need to replace the control board.
Simon.
Replaced Main Control Board and washer is working..."fried" resister on IC board.Ran washer 2x then this"error code e59"-no tach sensor for 3 second.Ran washer 1 more cycle-then no more code but only now-drain pump is noisy/vibrates.Time to check/clean pump.Hopefully dont have to replace another pricey part again...Gotta love technology!!!
Groups: APP Team
I'm glad you fixed the problem.
Simon.
Washer Repair
