Joe_cole14
#1 Posted : Friday, August 24, 2012 6:25:06 AM(UTC)
Joe_cole14
I have a whirlpool washer that is not draining. I have checked the pump, line for clogs, the impella looks fine and have removed the PUMP MOTOR for testing. My QUESTION; WHEN CHECKING RESISTANCE AS PER THE MANUAL! DO I TEXT WITH THE CAPACITOR ATTATCHED TO THE HARNESS OR DISCONNECTED? TESTING with the capacitor ATTATCHED yields 1-2 ohms where the Manual calls for 10-20 depending on the leads. If I test just the motor, unattached the meter reads infinity. I think the motor is bad but would like some confirmation before I replace it. Any help would be appreciated as the wife is getting cranky. I had 2 repair guys here yesterday, One said it was the helical drive, he seems questionable, and the second thought it was the pump motor but said it would be $400 to fix. So here I am.
Thanks again for looking.
Joe
Simon / APP Team
#2 Posted : Friday, August 24, 2012 1:55:15 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The continuity check must be done without the capacitor.
If the pump is getting 120VAC to it when in the drain cycle - replace the pump Part number: 285990
Part number: 285990
Simon.
