Discuss
Kenmore washer will not spin in high speed
 in
Washer Repair
Kenmore front loading washer. Same as a Duet. The washer will fill with water. The motor will slowly move the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer will not spin in high speed
  #1 (permalink)
Old 08-23-2012, 08:57 PM
Junior Member
jjlittle.64 is on a distinguished road
Default Kenmore washer will not spin in high speed
Model Number: 11047511702   Brand: Kenmore   Age: 1 - 5 years
Kenmore front loading washer. Same as a Duet. The washer will fill with water. The motor will slowly move the drum when empty, but would only nudge the drum when full. The motor never goes to a high speed spin. The motor (or possibly a relay somewhere near the motor) makes a clicking noise. When it is slow spinning. After about a minute, the whole thing shuts down. When I restart the washer and start the rinse cycle again, it pumps out the water just fine and starts to fill it up again. I have taken the back off and inspected the belt and pulley. They are fine. The drum free spins fine. I,m guessing the MCU, possibly the motor. If the motor was bad, would it just not turn at all? Any help would be appreciated.
Related Models
Kenmore 11047511702 RESIDENTIAL WASHER
Kenmore 11047512600 RESIDENTIAL WASHER
Kenmore 11047512601 RESIDENTIAL WASHER
Kenmore 11047512602 RESIDENTIAL WASHER
Kenmore 11047512603 RESIDENTIAL WASHER
Kenmore 11047512604 RESIDENTIAL WASHER
Kenmore 11047512605 RESIDENTIAL WASHER
Kenmore 11047531700 RESIDENTIAL WASHER
Kenmore 11047531701 RESIDENTIAL WASHER
Kenmore 11047531702 RESIDENTIAL WASHER
Kenmore 11047532600 RESIDENTIAL WASHERS
Kenmore 11047532601 RESIDENTIAL WASHER
Kenmore 11047532602 RESIDENTIAL WASHER
Kenmore 11047532603 RESIDENTIAL WASHER
Kenmore 11047532604 RESIDENTIAL WASHER
Kenmore 11047532605 RESIDENTIAL WASHER
Kenmore 11047542600 RESIDENTIAL WASHER
Kenmore 11047542601 RESIDENTIAL WASHER
Kenmore 11047542602 RESIDENTIAL WASHER
Kenmore 11047542603 RESIDENTIAL WASHER
Kenmore 11047542604 RESIDENTIAL WASHER
Kenmore 11047542605 RESIDENTIAL WASHER
Kenmore 11047561600 RESIDENTIAL WASHERS
Kenmore 11047561601 RESIDENTIAL WASHER
Kenmore 11047561602 RESIDENTIAL WASHER
Kenmore 11047561603 RESIDENTIAL WASHER
Kenmore 11047561604 RESIDENTIAL WASHER
Kenmore 11047562700 RESIDENTIAL WASHER
Kenmore 11047566600 RESIDENTIAL WASHERS
Kenmore 11047566601 RESIDENTIAL WASHER
Kenmore 11047566602 RESIDENTIAL WASHER
Kenmore 11047566603 RESIDENTIAL WASHER
Kenmore 11047567700 RESIDENTIAL WASHER
Kenmore 11047567701 RESIDENTIAL WASHER
Kenmore 11047571600 RESIDENTIAL WASHERS
Kenmore 11047571601 RESIDENTIAL WASHER
Kenmore 11047571602 RESIDENTIAL WASHER
Kenmore 11047571603 RESIDENTIAL WASHER
Kenmore 11047571604 RESIDENTIAL WASHER
Kenmore 11047572700 RESIDENTIAL WASHERS
Kenmore 11047576600 RESIDENTIAL WASHERS
Kenmore 11047576601 RESIDENTIAL WASHER
Kenmore 11047576602 RESIDENTIAL WASHER
Kenmore 11047576603 RESIDENTIAL WASHER
Kenmore 11047577700 RESIDENTIAL WASHER
Kenmore 11047577701 RESIDENTIAL WASHER
Kenmore 11047581600 RESIDENTIAL WASHERS
Kenmore 11047581601 RESIDENTIAL WASHER
Kenmore 11047581602 RESIDENTIAL WASHER
Kenmore 11047581603 RESIDENTIAL WASHER
Kenmore 11047581604 RESIDENTIAL WASHER
Kenmore 11047602940 WASHER
Kenmore 11047661950 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11047662950 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11047701800 RESIDENTIAL WASHER
Kenmore 11047701801 WASHER
Kenmore 11047711800 RESIDENTIAL WASHER
Kenmore 11047711801 WASHER
Kenmore 11047751800 WASHER
Kenmore 11047751801 WASHER
Kenmore 11047761800 RESIDENTIAL WASHER
Kenmore 11047761801 WASHER
Kenmore 11047781700 RESIDENTIAL WASHER
Kenmore 11047781701 RESIDENTIAL WASHER
Kenmore 11047781702 WASHER
Kenmore 11047787800 WASHER
Kenmore 11047787801 WASHER
Kenmore 11047788800 WASHER
Kenmore 11047788801 WASHER
Kenmore 11047789700 RESIDENTIAL WASHER
Kenmore 11047789701 RESIDENTIAL WASHER
Kenmore 11047789702 WASHER
Kenmore 11047791700 RESIDENTIAL WASHER
Kenmore 11047791701 RESIDENTIAL WASHER
Kenmore 11047791702 WASHER
Kenmore 11047797800 RESIDENTIAL WASHER
Kenmore 11047797801 WASHER
Kenmore 11047798800 RESIDENTIAL WASHER
Kenmore 11047798801 WASHER
Kenmore 11047799701 RESIDENTIAL WASHER
Kenmore 11047799702 WASHER
Kenmore 11047852700 WASHER
Kenmore 11047852701 RESIDENTIAL WASHER
Kenmore 11047852702 RESIDENTIAL WASHER
Kenmore 11047852703 RESIDENTIAL WASHER
Kenmore 11047882700 WASHER
Kenmore 11047882701 RESIDENTIAL WASHER
Kenmore 11047882702 RESIDENTIAL WASHER
Kenmore 11047882703 RESIDENTIAL WASHER
Kenmore 11048182790 AUTOMATIC WASHER
Kenmore 11048182791 AUTOMATIC WASHER
Kenmore 11048184790 AUTOMATIC WASHER
Kenmore 11048184791 AUTOMATIC WASHER
Kenmore 11048722790 COMPACT AUTOMATIC WASHER
Kenmore 11048722791 COMPACT AUTOMATIC WASHER
Kenmore 11048724790 COMPACT AUTOMATIC WASHER
Kenmore 11048724791 COMPACT AUTOMATIC WASHER
Kenmore 11049182990 AUTOMATIC WASHER
Kenmore 11049182991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11049962600 WASHER
Kenmore 11049962601 RESIDENTIAL WASHER
Kenmore 11049962602 RESIDENTIAL WASHER
Kenmore 11049962603 RESIDENTIAL WASHER
Kenmore 11049972600 RESIDENTIAL WASHER
Kenmore 11049972601 RESIDENTIAL WASHER
Kenmore 11049972602 RESIDENTIAL WASHER
Kenmore 11049972603 RESIDENTIAL WASHER
Kenmore 1105062110 WASHER
Kenmore 110508802 KENMORE ELECTRIC DRYER
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
  #2 (permalink)
Old 08-24-2012, 12:00 AM
Junior Member
Default
Also. I do not get any type of error code. It just shuts down.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 417 won't spin high speed when loaded needhelpinUT Washer Repair 2 06-02-2013 07:48 AM
GE Washer won't spin high speed fbrr Washer Repair 0 01-23-2012 08:44 AM
GE 2 speed washer won't spin in high speed buzzybucks Washer Repair 1 12-16-2011 05:53 PM
Kenmore Front Load Washer - No High Speed Spin BLKJAK Washer Repair 4 05-13-2011 08:10 AM
washer will not go into high speed spin rocco riganati Washer Repair 1 05-11-2011 07:44 AM
