ldonner
#1 Posted : Tuesday, August 21, 2012 5:01:48 PM(UTC)
ldonner
S/S inner barrel is eating the front half of tub? whats happening? Already replaced front half of tub and boot which now i know are the result and not the problem. please help!!!!
#2 Posted : Wednesday, August 22, 2012 2:41:52 PM(UTC)
Pull the washer out of the wall and remove the rear panel. Check the nut (#1 at the diagram). If it became loose then the inner tub moved forward causing those damages. Very likely the rear outer tub has to be replaced.
- The rear outer tub Part number: W10253866
- The front outer tub Part number: 285982
Part number: 285982
Whirlpoool Duet not spinning clothes dry (Washer Repair)
by AdamsBT1 4/9/2022 6:03:49 AM(UTC)
