Washer stops running about 10 seconds after it starts to agitate. After a while it will start up and run for another 10 seconds and then stops.:confused: What do I do?
Groups: APP Team
Hi. Remove the toe panel and when motor stops after 10 sec. check if it's extremely hot and turns back on without you doing anything. If it's not - wiggle the timer slightly. If the motor comes on by itself - bad motor or jammed transmission or drain pump. If it's starts after you play with the timer - replace the timer. Here are the breakdown diagrams and Replacement parts for Maytag SAV515DEWW WASHER-TOP LOADING | AppliancePartsPros.comThank you. Simon.
Originally Posted by: Simon / APP Team Hi. Remove the toe panel and when motor stops after 10 sec. check if it's extremely hot and turns back on without you doing anything. If it's not - wiggle the timer slightly. If the motor comes on by itself - bad motor or jammed transmission or drain pump. If it's starts after you play with the timer - replace the timer. Here are the breakdown diagrams and Replacement parts for Maytag SAV515DEWW WASHER-TOP LOADING | AppliancePartsPros.comThank you. Simon. Motor is very hot. Removed belt so only the pump was connected, same thing. Pump works fine on spin cycle.
Groups: APP Team
Hi.
Before replacing the motor make sure the pump is not the reason.
Simon.
