Discuss
Washer will fill, drain, spin but won't agitate
 in
Washer Repair
I have a GE washer that fills up OK and when it starts to agitate I get a clicking noise
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will fill, drain, spin but won't agitate
  #1 (permalink)
Old 01-28-2008, 09:26 PM
tmatsick tmatsick is offline
Junior Member
tmatsick is on a distinguished road
Default Washer will fill, drain, spin but won't agitate
Brand: GE   Age: 1 - 5 years
I have a GE washer that fills up OK and when it starts to agitate I get a clicking noise from down below... It seems like it is trying to go through the agitation cycle but is not quite getting it done. You can hear the motor start and then the click and stop. Motor, click, stop etc. I can set the washer to spin and it will pump out the water and spin with seemingly no problem. Sooo.... I question is could it be the control panel and not driving the motor correctly or could it be the motor itself. Or maybe even the transmission? Not sure any ideas would be great!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-29-2008, 03:05 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide the most accurate advise I need the complete model number of the washer.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-29-2008, 06:09 PM
Junior Member
Default Model #
Sorry...
Model - WBSE3120B1WW
S/N - SD158762G
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool washer does not fill but does agitate lambert Washer Repair 1 01-24-2008 06:04 PM
Will fill, but it won't agitate, spin or drain ed0410 Washer Repair 5 12-11-2007 02:54 PM
Washer will fill and wash, but not spin and empty cwp Washer Repair 0 11-06-2007 10:22 AM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 02:20 AM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
