I have an older Maytag SE7800 stacked laundry system (Maytag SE7800ADW) that I bought used and has been working fine. The washer is still working but the dryer refuses to turn on. I can set the rotary dial to selected dry program but when I press the switch I can hear a ticking and a hum but the dryer doesn't engage. I'm guessing the switch is maybe dead? (I can see a spark on the switch sometimes if I open the panel and press the switch -- I'm assuming that's not a good sign). Do you think I just need to buy a new switch (you sell them right)? Or is there something else that would give those symptoms (I saw mention of a fuse for another model?) machine is definitely getting power and is hooked up OK as it was working fine up until yesterday. Thanks I found this diagram: Front panel & control panel replacement parts for Maytag SE7800 STACKED LAUNDRY- ELE | AppliancePartsPros.com
