| » whirl cabrio balance problems |
Model Number: wtw63swd Brand: Whirlpool Age: 1 - 5 years
cabrio washer has frequent balance problems just started after 2 years unbalanced load retry sometimes straightens out load but often does not. we have replaced the drive and driven gear in tub ,replaced drain pump,checked tub bearing and balance rings still having problems with unbalanced loads about every other load. MODEL #WTW6300SWO
Ads By Google Related Models Last edited by washerman101 : 09-21-2009 at 07:04 AM. Reason: wrong model # |
Boy, given what you have done this is somewhat of a mystery, particular for this machine. The way it is designed this is not likely to happen, but that is not much comfort for you.
Check to see if the tub is settling correctly when it goes into the spin mode. The inner tub floats during the was cycle and drops back onto the drive shaft when it drains. It may not be dropping back correctly due to something caught in the tub or for some other reason. That's about all I got, maybe someone else can chime in with their thoughts.
__________________
| Display Modes | |
| Whirl pool Gold won't drain | MDimond | Dishwasher Repair | 0 | 12-26-2009 09:39 AM |
| Whirl Pool Dishwasher | JELLYGIRL72 | Dishwasher Repair | 1 | 07-08-2009 02:22 PM |
| Whirl Pool Washer will not drain or spin | beccap | Washer Repair | 7 | 03-24-2009 03:50 PM |
| Door broken - spring balance or door balance link | Lisa Keyko | Dishwasher Repair | 2 | 03-14-2009 07:35 AM |
| Whirlpool won't whirl! | Jim Parker | Dishwasher Repair | 4 | 09-28-2008 02:02 PM |
