I have a 4 year old Frigidaire front loading washer that has issues. It started about 8 mos ago when the start button would radomly flash and make a beeping sound as if you had put a load of laundry in. The washer would work normally except for the intermittent flashing and beeping of the start button. About a month ago after running a load of laundry it did not run the final spin and drain cycle. After doing some research, this model has a history of prolems with the computer board. I replaced the board and the intermittent flashing and beeping stopped but it doesn't run. When you start a wash cycle it will intially start and then stop. Any ideas?
Groups: APP Team
Hi.
Remove the toe panel and on the left side find the tech sheet. Run the diagnostic test.
Simon.
Simon. To get the toe panel off do you have to take the top of the washer off and disassemble the whole washer? I am not seeing how to get the front toe panel off.
Groups: APP Team
