Discuss
Whirlpool wont go into drain or spin cycle
 in
Washer Repair
Machine fills & washes normally then the timer will stop & not go into the drain / spin cycle unless
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool wont go into drain or spin cycle
  #1 (permalink)
Old 08-13-2012, 08:17 PM
Junior Member
MBsticks is on a distinguished road
Unhappy Whirlpool wont go into drain or spin cycle
Model Number: LSC8244DQO   Brand: Whirlpool   Age: More than 10 years
Machine fills & washes normally then the timer will stop & not go into the drain / spin cycle unless you manually move it there. This occurrs in any of the cycle settings around the dial. Is the problem the timer? or some other sensor.
Ads By Google
Related Models
Whirlpool LSC8244DZ0 AUTOMATIC WASHER
Whirlpool LSC8244EQ0 WASHER
Whirlpool LSC8244EQ1 WASHER
Whirlpool LSC8244EZ0 WASHER
Whirlpool LSC8244EZ1 WASHER
Whirlpool LSC8245AN0 AUTOMATIC WASHER
Whirlpool LSC8245AQ0 AUTOMATIC WASHER
Whirlpool LSC8245AW0 Washers*
Whirlpool LSC8245BW0 Washers*
Whirlpool LSC9000PW0 AUTOMATIC WASHER
Whirlpool LSC9000PW1 AUTOMATIC WASHER
Whirlpool LSC9000PW2 AUTOMATIC WASHER
Whirlpool LSC9245BN0 AUTOMATIC WASHER
Whirlpool LSC9245BN1 AUTOMATIC WASHER
Whirlpool LSC9245BQ0 AUTOMATIC WASHER
Whirlpool LSC9245BQ1 AUTOMATIC WASHER
Whirlpool LSC9245BW0 AUTOMATIC WASHER
Whirlpool LSC9245BW1 AUTOMATIC WASHER
Whirlpool LSC9245BZ0 AUTOMATIC WASHER
Whirlpool LSC9245BZ1 AUTOMATIC WASHER
Whirlpool LSC9355AG0 AUTOMATIC WASHER
Whirlpool LSC9355AN0 AUTOMATIC WASHER
Whirlpool LSC9355AW0 Washers*
Whirlpool LSC9355BN0 AUTOMATIC WASHER
Whirlpool LSC9355BN1 AUTOMATIC WASHER
Whirlpool LSC9355BQ0 AUTOMATIC WASHER
Whirlpool LSC9355BQ1 AUTOMATIC WASHER
Whirlpool LSC9355BW0 AUTOMATIC WASHER
Whirlpool LSC9355BW1 AUTOMATIC WASHER
Whirlpool LSC9355BZ0 AUTOMATIC WASHER
Whirlpool LSC9355BZ1 AUTOMATIC WASHER
Whirlpool LSC9355DQ0 AUTOMATIC WASHER
Whirlpool LSC9355DZ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ1 DIRECT-DRIVE WASHER
Whirlpool LSC9355EZ0 AUTOMATIC WASHER
Whirlpool LSC9355EZ1 DIRECT-DRIVE WASHER
Admiral LSD2615HEB REF - SXS/I&W
Admiral LSD2615HEW REF - SXS/I&W
Admiral LSD2615HEZ REF - SXS/I&W
Maytag LSE1000 STACKED LAUNDRY- ELE
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-8 STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-C STACKED LAUNDRY- ELE
Jenn-Air LSE2704W STACKED LAUNDRY- ELE
Jenn-Air LSE2704W-8 STACKED LAUNDRY- ELE
Maytag LSE7800 STACKED LAUNDRY- ELE
Maytag LSE7800ACE STACKED LAUNDRY- ELE
Maytag LSE7800ACL STACKED LAUNDRY- ELE
Maytag LSE7800ACW STACKED LAUNDRY- ELE
Maytag LSE7800ADE STACKED LAUNDRY- ELE
Maytag LSE7800ADL STACKED LAUNDRY- ELE
Maytag LSE7800ADW STACKED LAUNDRY- ELE
Maytag LSE7800AEE STACKED LAUNDRY- ELE
Maytag LSE7800AEL STACKED LAUNDRY- ELE
Maytag LSE7800AEW STACKED LAUNDRY- ELE
Admiral LSE7800AGE STACKED LAUNDRY- ELE
Admiral LSE7800AGL STACKED LAUNDRY- ELE
Maytag LSE7804ACE STACKED LAUNDRY- ELE
Maytag LSE7804ACL STACKED LAUNDRY- ELE
Maytag LSE7804ACM STACKED LAUNDRY- ELE
Maytag LSE7804ADE STACKED LAUNDRY- ELE
Maytag LSE7804ADL STACKED LAUNDRY- ELE
Maytag LSE7804ADM STACKED LAUNDRY- ELE
Maytag LSE7804AEE STACKED LAUNDRY- ELE
Admiral LSE7804AGE STACKED LAUNDRY- ELE
Admiral LSE7804AGL STACKED LAUNDRY- ELE
Admiral LSE7804AGM STACKED LAUNDRY- ELE
Maytag LSE7806ACE STACKED LAUNDRY- ELE
Maytag LSE7806ACM STACKED LAUNDRY- ELE
Maytag LSE7806ACQ STACKED LAUNDRY- ELE
Maytag LSE7806ADE STACKED LAUNDRY- ELE
Maytag LSE7806ADM STACKED LAUNDRY- ELE
Maytag LSE7806ADQ STACKED LAUNDRY- ELE
Maytag LSE7806AEE STACKED LAUNDRY- ELE
Maytag LSE7806BCE STACKED LAUNDRY- ELE
Admiral LSE7806GGE STACKED LAUNDRY- ELE
Whirlpool LSE9355BQ0
Whirlpool LSE9355BZ0
Maytag LSE9900 STACKED LAUNDRY- ELE
Maytag LSE9900ACE STACKED LAUNDRY- ELE
Maytag LSE9900ACL STACKED LAUNDRY- ELE
Maytag LSE9900ACW STACKED LAUNDRY- ELE
Maytag LSE9900ADE STACKED LAUNDRY- ELE
Maytag LSE9900ADL STACKED LAUNDRY- ELE
Maytag LSE9900ADW STACKED LAUNDRY- ELE
Maytag LSE9900AEE STACKED LAUNDRY- ELE
Maytag LSE9900AEL STACKED LAUNDRY- ELE
Maytag LSE9900AEW STACKED LAUNDRY- ELE
Maytag LSE9900AFL STACKED LAUNDRY- ELE
Maytag LSE9900AFW STACKED LAUNDRY- ELE
Maytag LSE9904ACE STACKED LAUNDRY- ELE
Maytag LSE9904ACL STACKED LAUNDRY- ELE
Maytag LSE9904ACM STACKED LAUNDRY- ELE
Maytag LSE9904ADE STACKED LAUNDRY- ELE
Maytag LSE9904ADL STACKED LAUNDRY- ELE
Maytag LSG1000 STACKED LAUNDRY- GAS
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W STACKED LAUNDRY- GAS
Jenn-Air LSG2704W STACKED LAUNDRY- GAS
Maytag LSG7800 STACKED LAUNDRY- GAS
Maytag LSG7800AAE STACKED LAUNDRY- GAS
Maytag LSG7800AAL STACKED LAUNDRY- GAS
Maytag LSG7800AAW STACKED LAUNDRY- GAS
Maytag LSG7800ABE STACKED LAUNDRY- GAS
Maytag LSG7800ABL STACKED LAUNDRY- GAS
Maytag LSG7800ABW STACKED LAUNDRY- GAS
Maytag LSG7804AAE STACKED LAUNDRY- GAS
Maytag LSG7804AAL STACKED LAUNDRY- GAS
Maytag LSG7804AAM STACKED LAUNDRY- GAS
Maytag LSG7804ABE STACKED LAUNDRY- GAS
Maytag LSG7804ABL STACKED LAUNDRY- GAS
Maytag LSG7804ABM STACKED LAUNDRY- GAS
Maytag LSG7806AAE STACKED LAUNDRY- GAS
Maytag LSG7806AAM STACKED LAUNDRY- GAS
Maytag LSG7806AAQ STACKED LAUNDRY- GAS
Maytag LSG7806ABE STACKED LAUNDRY- GAS
Maytag LSG7806ABM STACKED LAUNDRY- GAS
Maytag LSG7806ABQ STACKED LAUNDRY- GAS
  #2 (permalink)
Old 08-14-2012, 08:53 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
If the motor will not run, either you have a bad timer, or bad lid switch. If the lid switch clicks when the lid is closed, remove the timer cover and check for burnt contacts. If so, replace the timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 Spin Cycle Grinds, wont drain losositos Washer Repair 1 09-07-2012 12:15 PM
Washer wont drain/ stops at spin cycle vick7 Washer Repair 1 11-24-2011 06:09 PM
Whirlpool DW wont drain during cycle-but will if i hit drain after lowstepside Dishwasher Repair 0 09-06-2011 11:17 AM
washer wont drain after spin cycle david roberts Washer Repair 0 08-01-2009 12:52 PM
