Discuss
Maytag washer - repair or replace?
 in
Washer Repair
I have a Maytag LAT9206BAE top-loading washer that it stopped spinning/draining today. I've reset it to the spin cycle a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer - repair or replace?
  #1 (permalink)
Old 08-13-2012, 07:20 PM
Junior Member
SpaceDawg is on a distinguished road
Default Maytag washer - repair or replace?
Model Number: LAT9206BAE   Brand: Maytag   Age: More than 10 years
I have a Maytag LAT9206BAE top-loading washer that it stopped spinning/draining today. I've reset it to the spin cycle a couple of times, and I could tell the motor was straining, smelled the belts a bit, then it would quit. I drained the water and opened the front: motor slides fine, and can't see any blockage to the water drainage. The belts underneath seem okay, I think. The main one has the correct slack (I can just pinch it together) and spins in both directions. The front belt spins easily in one direction, not so well in the other, and also might be a little slack (I can pinch it past the two sides touching). Looking inside, things look pretty normal - no sign of obvious leakage or corrosion.
From the little reading I've done, I suspect it's the spin bearing. The washer is over 10 years old (that how long I've owned the house), but I have no idea if it's much older than that. My main question is, should I have a repair person come out and properly diagnose things, or is it likely I should go ahead and get a new one?
Ads By Google
Related Models
Maytag LAT9206BAE WASHER-TOP LOADING
Maytag LAT9206BAM WASHER-TOP LOADING
Maytag LAT9206BAQ WASHER-TOP LOADING
Maytag LAT9206BBE WASHER-TOP LOADING
Maytag LAT9206BBM WASHER-TOP LOADING
Maytag LAT9235AAE WASHER-TOP LOADING
Maytag LAT9235AAM WASHER-TOP LOADING
Maytag LAT9280AAL WASHER-TOP LOADING
Maytag LAT9280AAW WASHER-TOP LOADING
Maytag LAT9280ABL WASHER-TOP LOADING
Maytag LAT9280ABW WASHER-TOP LOADING
Maytag LAT9300AAL WASHER-TOP LOADING
Maytag LAT9300AAW WASHER-TOP LOADING
Maytag LAT9300ABL WASHER-TOP LOADING
Maytag LAT9300ABW WASHER-TOP LOADING
Maytag LAT9304AAE WASHER-TOP LOADING
Maytag LAT9304AAL WASHER-TOP LOADING
Maytag LAT9304AAM WASHER-TOP LOADING
Maytag LAT9304ABE WASHER-TOP LOADING
Admiral LAT9304AGE WASHER-TOP LOADING
Admiral LAT9304AGL WASHER-TOP LOADING
Admiral LAT9304AGM WASHER-TOP LOADING
Admiral LAT9304BGE WASHER-TOP LOADING
Maytag LAT9304DAL WASHER-TOP LOADING
Maytag LAT9304DAM WASHER-TOP LOADING
Admiral LAT9304EGE WASHER-TOP LOADING
Admiral LAT9304GGE WASHER-TOP LOADING
Maytag LAT9306AAE WASHER-TOP LOADING
Maytag LAT9306AAM WASHER-TOP LOADING
Maytag LAT9306ABE WASHER-TOP LOADING
Admiral LAT9306AGE WASHER-TOP LOADING
Admiral LAT9306AKM WASHER-TOP LOADING
Admiral LAT9306AKQ WASHER-TOP LOADING
Admiral LAT9306BGE WASHER-TOP LOADING
Admiral LAT9306DAM WASHER-TOP LOADING
Admiral LAT9306DAQ WASHER-TOP LOADING
Admiral LAT9306EGE WASHER-TOP LOADING
Admiral LAT9306GGE WASHER-TOP LOADING
Maytag LAT9314AAE WASHER-TOP LOADING
Maytag LAT9314AAL WASHER-TOP LOADING
Maytag LAT9314AAM WASHER-TOP LOADING
Maytag LAT9314ABE WASHER-TOP LOADING
Maytag LAT9316AAE WASHER-TOP LOADING
Maytag LAT9316AAM WASHER-TOP LOADING
Maytag LAT9316ABE WASHER-TOP LOADING
Maytag LAT9316ABM WASHER-TOP LOADING
Maytag LAT9334AAE WASHER-TOP LOADING
Maytag LAT9334AAL WASHER-TOP LOADING
Maytag LAT9334AAM WASHER-TOP LOADING
Maytag LAT9334ABE WASHER-TOP LOADING
Maytag LAT9356AAE WASHER-TOP LOADING
Maytag LAT9356AAM WASHER-TOP LOADING
Maytag LAT9356AAQ WASHER-TOP LOADING
Maytag LAT9356ABE WASHER-TOP LOADING
Maytag LAT9356ABM WASHER-TOP LOADING
Maytag LAT9357AAE WASHER-TOP LOADING
Maytag LAT9357AAM WASHER-TOP LOADING
Maytag LAT9357AAQ WASHER-TOP LOADING
Maytag LAT9360AAE WASHER-TOP LOADING
Maytag LAT9390AAE WASHER-TOP LOADING
Maytag LAT9400AAE WASHER-TOP LOADING
Maytag LAT9400AAL WASHER-TOP LOADING
Maytag LAT9400AAW WASHER-TOP LOADING
Maytag LAT9400ABE WASHER-TOP LOADING
Maytag LAT9400ABL WASHER-TOP LOADING
Maytag LAT9400ABW WASHER-TOP LOADING
Maytag LAT9400AGL WASHER-TOP LOADING
Maytag LAT9400AGW WASHER-TOP LOADING
Maytag LAT9400DAL WASHER-TOP LOADING
Maytag LAT9400DAW WASHER-TOP LOADING
Maytag LAT9406AAE WASHER-TOP LOADING
Maytag LAT9406AAM WASHER-TOP LOADING
Maytag LAT9406ABE WASHER-TOP LOADING
Maytag LAT9416AAE WASHER-TOP LOADING
Maytag LAT9416AAM WASHER-TOP LOADING
Maytag LAT9416AAQ WASHER-TOP LOADING
Maytag LAT9420AAE WASHER-TOP LOADING
Maytag LAT9457AAE WASHER-TOP LOADING
Maytag LAT9457AAM WASHER-TOP LOADING
Maytag LAT9457AAQ WASHER-TOP LOADING
Maytag LAT9457BAE WASHER-TOP LOADING
Maytag LAT9520AAE WASHER-TOP LOADING
Maytag LAT9520AAQ WASHER-TOP LOADING
Maytag LAT9557AAE WASHER-TOP LOADING
Maytag LAT9557AAQ WASHER-TOP LOADING
Maytag LAT9593AAL WASHER-TOP LOADING
Maytag LAT9593AAW WASHER-TOP LOADING
Maytag LAT9593ABL WASHER-TOP LOADING
Maytag LAT9593ABW WASHER-TOP LOADING
Maytag LAT9600AAL WASHER-TOP LOADING
Maytag LAT9600AAW WASHER-TOP LOADING
Maytag LAT9600ABL WASHER-TOP LOADING
Maytag LAT9600ABW WASHER-TOP LOADING
Maytag LAT9604AAE WASHER-TOP LOADING
Maytag LAT9604AAL WASHER-TOP LOADING
Maytag LAT9604AAM WASHER-TOP LOADING
Maytag LAT9604ABE WASHER-TOP LOADING
Maytag LAT9605AAE WASHER-TOP LOADING
Maytag LAT9605AAM WASHER-TOP LOADING
Maytag LAT9606AAE WASHER-TOP LOADING
Maytag LAT9606AAM WASHER-TOP LOADING
Maytag LAT9606ABE WASHER-TOP LOADING
Maytag LAT9606ABM WASHER-TOP LOADING
Admiral LAT9606AGE WASHER-TOP LOADING
Admiral LAT9606BGE WASHER-TOP LOADING
Admiral LAT9606GGE WASHER-TOP LOADING
Maytag LAT9614AAE WASHER-TOP LOADING
Maytag LAT9614AAL WASHER-TOP LOADING
Maytag LAT9614AAM WASHER-TOP LOADING
Maytag LAT9615AAE WASHER-TOP LOADING
Maytag LAT9615AAM WASHER-TOP LOADING
Maytag LAT9616AAE WASHER-TOP LOADING
Maytag LAT9616AAM WASHER-TOP LOADING
Maytag LAT9634AAE WASHER-TOP LOADING
Maytag LAT9634AAL WASHER-TOP LOADING
Maytag LAT9634AAM WASHER-TOP LOADING
Maytag LAT9634ABE WASHER-TOP LOADING
Maytag LAT9635AAE WASHER-TOP LOADING
Maytag LAT9635AAM WASHER-TOP LOADING
Maytag LAT9700AAL WASHER-TOP LOADING
  #2 (permalink)
Old 08-14-2012, 12:29 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Remove the belt and check the pump, might have bad bearings.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how to repair or replace washer transmission elam Washer Repair 1 02-17-2012 04:52 PM
Kitchen Aid Washer - Repair or Replace??? schoolbusdriver9906 Washer Repair 1 01-02-2012 02:24 PM
Maytag Washer repair feevbee Washer Repair 1 08-06-2011 06:00 PM
repair or replace washer vforce2292 Washer Repair 0 04-22-2010 06:02 AM
Maytag Washer Repair parrisk Washer Repair 3 06-05-2009 06:11 AM
