Discuss
Washer stops after filling up
 in
Washer Repair
My washer will fill up with water and then stop. It makes no noises. If you bang on the side
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer stops after filling up
  #1 (permalink)
Old 08-12-2012, 08:07 PM
Junior Member
cblevins is on a distinguished road
Default Washer stops after filling up
Brand: Whirlpool   Age: 5 - 10 years
My washer will fill up with water and then stop. It makes no noises. If you bang on the side of it, it will eventually kick in to next cycle and finish. Could this be the lid switch or timer gone bad?
Ads By Google
  #2 (permalink)
Old 08-13-2012, 10:41 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Please provide the complete model number.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-13-2012, 04:39 PM
Junior Member
Default
LS09549PG2 is the model number
  #4 (permalink)
Old 08-14-2012, 12:05 PM
Expert
Default
Hi.
First check the lid switch. You can install a temporary jumper wire between GY and W at the lid switch.
If the washer starts - replace the lid switch
Part number: 8318084
If not check the water level switch contacts V - T should be closed (with water inside). Use the multimeter to do the continuity test.
The water level Part number: W10339326
Here are the breakdown diagrams and Replacement parts for Whirlpool LSQ9549PG2 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
__________________
  #5 (permalink)
Old 08-14-2012, 06:52 PM
Junior Member
Default
I replaced the lid switch and it is doing better. The washer will fill up and now your have push the dial in on the timer, advance the arrow just a little and pull the dial back out and the machine will start. Should I go ahead and replace the water level switch? Thanks very much for the advice.
  #6 (permalink)
Old 08-15-2012, 11:00 AM
Expert
Default
Hi.
It sounds like the timer is acting up.
Did you run the lid switch and the water level tests as I suggested? You would know for sure if the parts need replacement.
The timer Part number: 8557301
Simon.
__________________
  #7 (permalink)
Old 08-15-2012, 11:19 AM
Junior Member
Default
Thanks for the help. I replaced the lid switch with a new one and it is working much better. Thanks for all the help.
  #8 (permalink)
Old 08-16-2012, 10:04 AM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer stops while filling. Grawlt Washer Repair 0 01-14-2012 02:14 PM
washer stops before filling chrischr64 Washer Repair 1 07-13-2011 07:10 AM
GE Washer Stops Filling When Empty Explore10 Washer Repair 1 12-30-2009 08:15 AM
Washer stops after filling up denisesabo Washer Repair 0 06-28-2009 06:20 PM
Washer stops after filling with water golfnut77 Washer Repair 1 02-26-2008 02:38 PM
