| » Amana fills with H20 then motor hums and smokes |
Model Number: LDW70AW Brand: Amana Age: 5 - 10 years
Washer fills with water but won't agitate. I bailed out the water, disassembled the unit and the motor purrs when not under load. I checked the pump, turns freely. The clothes basket turns in one direction fine. The motor does hesitate in one section as I rotate the timer control before kicking in fine.
The motor is $270 bucks and I don't want to make that investment if something cheaper could be the cause. Any suggestions would be greatly apprieciated. |
Did you try to move the transmission pulley in both directions?
If it moves freely then the problem is the motor. If it does not then the problem is the transmission. Gene. P.S. The model number you posted is incorrect.
__________________
Professional appliance repair in Los Angeles, California. |
Gene,
Actually, when I turn the drum clockwise and really force it, it squels and then it's hard to get it to rotate the other way again. I also noticed that when I move the drum there is a sloshing sound even though I have disconnected the pump hoses and have had the whole drum assembly laying on it's side. What the..??? JP |
| Display Modes | |
| Gas dryer motor hums but won't start | nonqual | Dryer Repair | 5 | 12-27-2007 05:40 AM |
| Hums when start is pressed then does nothing | Jacy213 | Dryer Repair | 3 | 09-19-2007 06:51 AM |
| Washer motor hums, but won't drain, agitate or spin | redwood646 | Washer Repair | 2 | 09-11-2007 08:39 PM |
| Maytag Washer just hums | spurzem | Washer Repair | 0 | 08-22-2007 11:17 AM |
| DW has power and fills, but motor won't run | chuck67 | Dishwasher Repair | 5 | 07-29-2007 05:53 PM |
