| » Please help me pin point part I need to fix spinning problem |
Model Number: WBVH5200J2WW Brand: GE Age: 1 - 5 years
On washing cyclesit looks like it wants to tumble (moves slightly but that’s it) and it eventuallygoes into pause. Rinse and spin cycle it does test tumble back and forth, unlocksdoor, locks door then rinses, then eventually goes to pause mode (no spin) On drainand spin cycle it drains and tries to spin then shuts down, and goes to pause. Ihave gone over the basics like cleaning the filter and looking at my drain hoseand they are fine. I put it in service mode and here are the results:
T01 = on #5 (for my model) T02 = E-48 is the only fault code but that code is not listedon troubleshooting chart T03 = COD is 400 , EEis 025 , INV is 143 T04 = All buttons light up and beep when pressed T05 = “P” and pumps for 60 seconds T06 = start-desplays “E” reached “F” reached “NF” , filledto “OF” and then drained T07 = displayed “0” while it switched from cold to hot then drained T08 = Not listed on manual , did not do T09 = Not listed on manual , did not do T10 = Tumbled one way then the other just fine , pressed powerbutton to stop test and it drained and returned to T10 (not sure if was supposeto drain T11 = drained first then spins 400 rpm , pressed start and spinsto 1000 rpm, pressed power to stop spinning and it drained , then went back to displayT11 T12 = worked as stated on manual T13 = I did not do NOTE : I tried T10 with some wet towels in washer and it workeda few times back and forth then stopped without me stopping it I tried T11 the same wet towels and it started spinning but Ihad to stop it because it was out of balance. Tried another time on T11 with same towels in it and it wouldnot spin at all. Any thought or suggestions on what needs to be replaced wouldbe greatly appreciated Thank You , Keith Mac Read more: Need help trouble shooting washer not spinning http://forum.appliancepartspros.com Ads By Google Related Models |
| Display Modes | |
| Spinning problem | RC Cola | Washer Repair | 1 | 08-08-2011 07:28 PM |
| Top part of Agitator not spinning (Whirlpool) | ronaldjp | Washer Repair | 3 | 05-06-2011 10:27 PM |
| Freezer Drive Auger (Fork part) is spinning but not despensing ice | kjenkins7 | Refrigerator & Freezer Repair | 3 | 10-28-2010 02:01 PM |
| Whirlpool washer not agitating or spinning. Top part of agitator is also very loose | jennifer johns | Dishwasher Repair | 0 | 02-06-2010 06:47 AM |
| Spinning Problem | JMS1953 | Washer Repair | 4 | 12-16-2008 09:40 PM |
