| » washer won't agitate or spin |
Model Number: GLTF1670ASG Brand: Frigidaire Age: 1 - 5 years
After using this site to find a problem I had with my washer not draining I removed the mangled popsicle stick from the drain pump inlet and put everything back together to discover the washer would now drain but not agitate or spin. I hear the switches cycling but no agitation. I might add that I heard a popping sound when I was moving the washer back into place but I didn't smell anything. Any advice would be greatly appreciated...
Are there fuses...? Ads By Google Related Models |
Check to see that the belt is not broken.
If it is ok, a possible problem is the speed control board. Here is the service manual which will show you how to do some troubleshooting. See page 50 in particular. http://frigidaireservicetips.com/pdf...ionWashers.pdf
__________________
| Display Modes | |
| Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) | cowboys#1 | Washer Repair | 8 | 01-13-2011 10:13 AM |
| Washer will agitate but not spin/spin slowly | sainthooligan | Washer Repair | 11 | 07-24-2010 10:34 AM |
| Washer won't spin or agitate | aprilfarmer | Washer Repair | 1 | 12-09-2009 05:17 PM |
| GE washer will not spin nor agitate | Evans | Washer Repair | 1 | 05-19-2009 06:01 PM |
| washer won't spin or agitate | cindyahouser | Washer Repair | 0 | 04-20-2009 02:34 PM |
