Discuss
HELP! Frigidaire front loader won't work
 in
Washer Repair
After reading several online articles / forums, I still can't get my washer to work. A while back, I noticed
Appliance Repair Forum > Appliance Repair Help > Washer Repair » HELP! Frigidaire front loader won't work
  #1 (permalink)
Old 08-05-2012, 04:44 PM
Junior Member
Caprice42 is on a distinguished road
Default HELP! Frigidaire front loader won't work
Model Number: LTF2140FSO   Brand: Frigidaire   Age: 1 - 5 years
After reading several online articles / forums, I still can't get my washer to work. A while back, I noticed that my washer kept stopping (unlocking for a second) and starting (relocking and continuing) during the cycle. But it still worked fine other than that, so I assumed that the machine just thought it was off balance or something. Then it stopped completing cycles and my clothes would be sitting in water that didn't appear to be clean / rinsed, but I could complete the load by unplugging the machine / plugging it back in to get the buttons to work, then switching it to the rinse / spin option, so I did that for a while. Then it stopped working entirely, and the buttons / dials aren't responsive. After a lot of online research, I checked for clogs - first in the hose between the washer and the wall (got some water pushing out of the machine when I snaked from the hole at the top / back of the machine down to the bottom of the machine, but never found a clog). It seemed to temporarily work off and on, then went back to leaving clothes in water and buttons / dials not working. Then I checked the same hose again, and took off the panel at the front / bottom of the machine and checked the hose going from the drain pump out of the machine, as well as the hose from the drum to the drain pump, and also the filter inside the drain pump boot. No clogs, and the filter was empty except for 2 pennies. I put everything back together, and still no luck. So then I ordered the door latch assembly, replaced that today, and nothing is happening / machine is still unresponsive since I plugged it back in. My only other option I can think of is replacing the door strike. I really can't afford a service call, if anyone has any suggestions / ideas I would greatly appreciate it.
Ads By Google
Related Models
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
Whirlpool LUD2100X6
Whirlpool LUD2100X7
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
Whirlpool LV55
Whirlpool LV551
Whirlpool LV5511
Whirlpool LV651
Whirlpool LVA4000W0
Whirlpool LVA4000W1
Whirlpool LVA4000W2
Whirlpool LVA4000W3
Whirlpool LVA4000W4
Whirlpool LVA4000W5
Whirlpool LVA4000W6
Whirlpool LVA4000W7
Whirlpool LVA4005W0
Whirlpool LVA4005W1
Whirlpool LVA4005W2
Whirlpool LVA4005W3
Whirlpool LVA4005W4
Whirlpool LVA4005W5
Whirlpool LVA4005W6
Whirlpool LVA4005W7
Whirlpool LVA4800W0
Whirlpool LVA4805W0
Whirlpool LVA4805W1
Whirlpool LVA5300W0
Whirlpool LVA5300W1
Whirlpool LVA5304W0
Whirlpool LVA5304W1
Whirlpool LVA5305W0
Whirlpool LVA5305W1
Whirlpool LVA5309W0
Whirlpool LVA5309W1
Whirlpool LVA5400W0
Whirlpool LVA5405W0
Whirlpool LVA5500W0
Whirlpool LVA5505W0
Whirlpool LVA5540W0
Whirlpool LVA5540W1
Whirlpool LVA5545W0
Whirlpool LVA5545W1
Whirlpool LVA5560W0
Whirlpool LVA5560W1
Whirlpool LVA5565W0
Whirlpool LVA5565W1
Whirlpool LVA6300W0
Whirlpool LVA6304W0
Whirlpool LVA6305W0
  #2 (permalink)
Old 08-06-2012, 01:49 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Do not replace the strike unless it's broken.
Check the disconnect plugs at the control board and wire harness.
If that checks OK - replace the control board
Part number: 137005000
Here are the breakdown diagrams and Replacement parts for Frigidaire LTF2140FS0 Frigidaire/washer | AppliancePartsPros.com
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-06-2012, 03:20 PM
Junior Member
Default
Thanks Simon, I will. How do I check the disconnect plugs?
  #4 (permalink)
Old 08-07-2012, 08:56 AM
Expert
Default
Hi.
Make sure they are making a good connection.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire gallery front loader mercurygirl Washer Repair 1 02-22-2012 11:34 AM
frigidaire front loader caleno Washer Repair 3 11-14-2010 05:32 PM
Frigidaire front loader seminole Washer Repair 2 07-19-2010 06:20 AM
Frigidaire Front Loader won't run hguyette Washer Repair 3 06-29-2009 11:15 AM
frigidaire front loader charles schaus Washer Repair 1 04-06-2009 07:04 PM
