| » washer fills and stops |
Model Number: AAV7000AWW Brand: Admiral Age: 1 - 5 years
Washer will sometimes fill, and stop. My wife will have to advance the timer by hand for agitation to start. At other times, washer advances fine. I replaced the timer with a brand new one, but the problem did not go away.
Quote:
The next time it doesn’t start properly when full unplug the washer at the outlet and connect the jumper directly between terminals 11 and 14 on the water level pressure switch, (that’s between the gray and blue wires) (see pic below) then plug the washer back in. If it starts then the washer needs a new pressure switch. |
| Display Modes | |
| Washer Fills, Then Stops | yogivic54 | Washer Repair | 5 | 04-11-2011 06:57 PM |
| Maytag washer fills then stops | kate59 | Washer Repair | 1 | 10-04-2009 12:35 PM |
| washer fills then stops | julie larson | Washer Repair | 3 | 01-07-2009 03:55 AM |
| Maytag Washer fills then stops | Tazman | Washer Repair | 4 | 01-23-2008 12:44 PM |
