Discuss
leaking washer
 in
Washer Repair
My washer has been falling apart, first the agitator stopped turning with a full load (ok if 1/2 or less)
Appliance Repair Forum > Appliance Repair Help > Washer Repair » leaking washer
  #1 (permalink)
Old 08-03-2012, 03:11 PM
Junior Member
martha725 is on a distinguished road
Question leaking washer
Brand: Kenmore   Age: More than 10 years
My washer has been falling apart, first the agitator stopped turning with a full load (ok if 1/2 or less) and now it's started leaking. I have checked the hoses and they are fine the water is coming out the bottom of the machine. Is this worth trying to fix?
Ads By Google
  #2 (permalink)
Old 08-05-2012, 05:47 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Without a model number I am going to assume that this is a direct drive Whirlpool made product and yes, if that is the case it is very much worth trying to fix.
Replace the agitator dogs to fix the agitator problem, and take off the cabinet and you should find out the pump is the problem with the leak. Replace it and for what should be less than $50 in parts you should be fine for a long time. If you want to you can replace the coupling while you are replacing the pump and that should make it last even longer without another repair.
__________________
  #3 (permalink)
Old 08-06-2012, 07:10 AM
Junior Member
Default
Thanks, its model # 110.28822790.
I don't know how to take off the cover to get to the pump, is there anywhere to find info on that?
  #4 (permalink)
Old 08-06-2012, 08:26 AM
Senior Expert
APP Volunteer
Default
Here is the part
Part number: AP2907492
and you will see a link to a nice video that will show you how to open it up and get to the pump. If the pump is leaking you should see water around it, or rust on the clips.
It is an easy repair, but it helps to have a helper, but make sure the helper is really a helper and not just a supervisor.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leaking washer 03svrider Washer Repair 4 06-19-2011 03:32 PM
Leaking washer donandlynn Washer Repair 1 05-08-2011 03:56 PM
GE washer leaking jstorm Washer Repair 9 02-21-2010 10:45 AM
Leaking Washer echef75 Washer Repair 2 08-25-2009 05:32 AM
Kenmore elite washer is leaking under washer cbs Washer Repair 1 07-12-2009 06:27 PM
