Discuss
Washer Leak/Flood
 in
Washer Repair
HELP! Our old Maytag washer sprung a heavy leak and has flooded the second floor of our house. We were
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Leak/Flood
  #1 (permalink)
Old 08-02-2012, 11:16 AM
Junior Member
jimlfixit is on a distinguished road
Default Washer Leak/Flood
Model Number: A810   Brand: Maytag   Age: More than 10 years
HELP! Our old Maytag washer sprung a heavy leak and has flooded the second floor of our house. We were running a large load on the "soak" setting and whilst it was soaking, a lot of water just started pouring out of the bottom of the machine.
I've taken the front off and don't see where the leak was coming from. All hoses are attached and seem fine. I'm really afraid to run it again to see where the leak is as it was such a disaster last time. I took off the pump and it seems to be fine (not jammed up or leaking). Could it be the tub seal? Would water leak that badly from it if its gone? Anyone have any advise?
Thanks!
Ads By Google
Related Models
Maytag A810 Washer - Top Loading
Maytag A8100 Washer - Top Loading
Maytag A8120 Washer - Top Loading
Maytag A8140 Washer - Top Loading
Maytag A8200 Washer - Top Loading
Maytag A8210 Washer - Top Loading
Admiral A8210PA Surface Unit - Gas
Admiral A8210PA-L Surface Unit - Gas
Admiral A8210PT-L Surface Unit - Gas
Admiral A8210PW Surface Unit - Gas
Admiral A8210PW-L Surface Unit - Gas
Admiral A8211PA Surface Unit - Gas
Admiral A8211PS Surface Unit - Gas
Admiral A8211PW Surface Unit - Gas
Maytag A8240 Washer - Top Loading
Admiral A8241RA Surface Unit - Gas
Admiral A8241RA-L Surface Unit - Gas
Admiral A8241RS Surface Unit - Gas
Admiral A8241RT-L Surface Unit - Gas
Admiral A8241RV Surface Unit - Gas
Admiral A8241RW Surface Unit - Gas
Admiral A8241RW-L Surface Unit - Gas
Admiral A8261RB Surface Unit - Gas
Admiral A8261RV Surface Unit - Gas
Admiral A82LK-3K-R Surface Unit - Gas
Admiral A82LN-3K-R Surface Unit - Gas
Admiral A82LW-2K-R Surface Unit - Gas
Admiral A82R1RV Surface Unit - Gas
Admiral A8321PA Surface Unit - Gas
Admiral A8321PS Surface Unit - Gas
Admiral A8321PW Surface Unit - Gas
Admiral A8321TA-L Surface Unit - Gas
Admiral A8321TW-L Surface Unit - Gas
Maytag A8340 Washer - Top Loading
Maytag A8420 Washer - Top Loading
Maytag A8440 Washer - Top Loading
Maytag A8500 Washer - Top Loading
Maytag A8520 Washer - Top Loading
Maytag A8600 Washer - Top Loading
Admiral A8610PA Surface Unit - Ele
Admiral A8610PS Surface Unit - Ele
Admiral A8610PV Surface Unit - Ele
Maytag A8640 Washer - Top Loading
Maytag A8650 Washer - Top Loading
Admiral A8670PB Surface Unit - Ele
Admiral A8670PV Surface Unit - Ele
Admiral A86LW-1-R Surface Unit - Ele
Maytag A8700 Washer - Top Loading
Admiral A8720PA Surface Unit - Ele
Admiral A8720PW Surface Unit - Ele
Maytag A8740 Washer - Top Loading
Maytag A8800 Washer - Top Loading
Maytag A882 Washer - Top Loading
Maytag A8820 Washer - Top Loading
Maytag A882T Washer - Top Loading
Maytag A883 Washer - Top Loading
Maytag A883T Washer - Top Loading
Maytag A884 Washer - Top Loading
Maytag A8840 Washer - Top Loading
Maytag A884T Washer - Top Loading
Admiral A88FK-1 Surface Unit - Ele
Admiral A88FK-2-R Surface Unit - Ele
Admiral A88FK-6-R Surface Unit - Ele
Admiral A88FN-2-R Surface Unit - Ele
Admiral A88FN-2R Surface Unit - Ele
Admiral A88LK-6-R Surface Unit - Ele
Admiral A88LN-6-R Surface Unit - Ele
Admiral A89L-4-R Surface Unit - Ele
Frigidaire A8LECUD2 Frg(v20) / Room Air Conditioner
Frigidaire A8MECC2 Frg(v15) / Room Air Conditioner
Frigidaire A8MECD2 Frg(v21) / Room Air Conditioner
Frigidaire A8MECUC2 Frg(v16) / Room Air Conditioner
Frigidaire A8MECUC3 Frg(v17) / Room Air Conditioner
Frigidaire A8MECUSC2 Frg(v6) / Room Air Conditioner
Frigidaire A8MECUSC3 Frg(v7) / Room Air Conditioner
Maytag A900 Washer - Top Loading
Maytag A900S Washer - Top Loading
Maytag A902 Washer - Top Loading
Maytag A906 Washer - Top Loading
Jenn-Air A910 Misc / Accessory
Admiral A9122VPV Walloven - Std Gas
Maytag A9200 Washer - Top Loading
Admiral A9211XPB Walloven - Cont Clean Gas
Admiral A9222VPV Walloven - Cont Clean Gas
Admiral A9222XPB Walloven - Cont Clean Gas
Maytag A9300 Washer - Top Loading
Maytag A9400 Washer - Top Loading
Maytag A9400S Washer - Top Loading
Maytag A9400W Washer - Top Loading
Admiral A9475VRV Walloven - S/c Gas
Admiral A9475XRB Walloven - S/c Gas
Admiral A9495VRV Range - S/c Mwave Gas
Admiral A9495XRB Range - S/c Mwave Gas
Maytag A9600 Washer - Top Loading
Maytag A9700 Washer - Top Loading
Maytag A9700S Washer - Top Loading
Maytag A9700W Washer - Top Loading
Maytag A9800 Washer - Top Loading
Admiral A9814XPB Walloven - S/c Ele
Admiral A9845VPV Walloven - S/c Ele
Admiral A9845XPB Walloven - S/c Ele
Admiral A9854VPV Walloven - S/c Ele
Admiral A9854XPB Walloven - S/c Ele
Admiral A9875VRV Walloven - S/c Ele
Admiral A9875XRB Walloven - S/c Ele
Admiral A9895VRV Walloven - S/c Mwave Ele
Admiral A9895XRB Walloven - S/c Mwave Ele
Maytag A9900 Washer - Top Loading
General Electric A9B568DAALSA Zoneline
General Electric A9B568EPASSA Zoneline
General Electric A9B678DAALWA Zoneline
General Electric A9B678EPASWA Zoneline
General Electric A9B688DAALW1 Zoneline
General Electric A9B688DAASW1 Zoneline
General Electric A9B688DEALW1 Zoneline
General Electric A9B688DEASW1 Zoneline
General Electric A9B688DJALW1 Zoneline
General Electric A9B688DJASW1 Zoneline
General Electric A9B688EPASW1 Zoneline
Maytag AA108 Washer - Top Loading
  #2 (permalink)
Old 08-02-2012, 01:36 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Most likely the tub seal is leaking, but you have to run the washer just for a short time to confirm the leaking part.
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Flood Damage - Maytag Neptune Washer sburtchin Washer Repair 6 03-19-2011 09:22 AM
washing machine flood tube leak macadotious Washer Repair 11 11-04-2010 05:25 AM
flood damage squier3 Washer Repair 2 09-22-2010 11:14 PM
Washer in Flood, now won't spin or agitate Janise Washer Repair 1 05-22-2009 06:25 AM
My washer fills and works okay but water seems to flood my floor ztait Washer Repair 0 07-02-2008 10:42 AM
