Discuss
New Maytag 2200 Front Loader
 in
Washer Repair
Maytag front loader just quit, was working perfectly, door is locked will not release, unplugged multiple times. Changed cycle, still
Appliance Repair Forum > Appliance Repair Help > Washer Repair » New Maytag 2200 Front Loader
  #1 (permalink)
Old 08-02-2012, 10:55 AM
Junior Member
macanic is on a distinguished road
Angry New Maytag 2200 Front Loader
Model Number: MHWE200XW00   Brand: Maytag   Age: 1 - 5 years
Maytag front loader just quit, was working perfectly, door is locked will not release, unplugged multiple times. Changed cycle, still no good, HELP>
Ads By Google
Related Models
Whirlpool MHWZ400TB00 Automatic Washer
Maytag MHWZ400TB00 Automatic Washer
Whirlpool MHWZ400TQ00 Automatic Washer
Maytag MHWZ400TQ00 Automatic Washer
Whirlpool MHWZ600TB00 Automatic Washer
Maytag MHWZ600TB00 Automatic Washer
Whirlpool MHWZ600TK00 Automatic Washer
Maytag MHWZ600TK00 Automatic Washer
Whirlpool MHWZ600TW00 Automatic Washer
Maytag MHWZ600TW00 Automatic Washer
General Electric MIG23MIMHFBB Refrigerator
General Electric MIG23MISAFBB Refrigerator
General Electric MIG23MISBFBB Refrigerator
Maytag MIP85S Misc / Accessory
Maytag MIP85T-2 Misc / Accessory
General Electric MK KIT 1
Whirlpool MK100
Whirlpool MK110
Jenn-Air MK241B Misc / Accessory
Jenn-Air MK241W Misc / Accessory
Jenn-Air MK24B Misc / Accessory
Jenn-Air MK24W Misc / Accessory
Jenn-Air MK271B Misc / Accessory
Jenn-Air MK271W Misc / Accessory
Jenn-Air MK272B Misc / Accessory
Jenn-Air MK272W Misc / Accessory
Jenn-Air MK27B Misc / Accessory
Jenn-Air MK27W Misc / Accessory
Jenn-Air MK301B Misc / Accessory
Jenn-Air MK301W Misc / Accessory
Jenn-Air MK302B Misc / Accessory
Jenn-Air MK302W Misc / Accessory
Jenn-Air MK30B Misc / Accessory
Jenn-Air MK30W Misc / Accessory
Amana ML-1 Mwave - Family Size (60 Hz)
Amana ML-10 Mwave - Family Size (60 Hz)
Amana ML-2 Mwave - Family Size (60 Hz)
Amana ML-3 Mwave - Family Size (60 Hz)
Whirlpool ML02CCXHW
Whirlpool ML02CCXHW1
Whirlpool ML03CCXHW
Whirlpool ML03CCXHW1
Whirlpool ML05CCXHW
Whirlpool ML05CCXHW1
Amana ML10 Mwave - Cntrtp / Stand Alone
Amana ML40 Mwave - Cntrtp / Stand Alone
Amana ML441T Mwave - Cntrtp / Stand Alone
Amana ML446P Mwave - Cntrtp / Stand Alone
Amana ML451T Mwave - Cntrtp / Stand Alone
Frigidaire MLCE52RCS0 Tap(v1) / Laundry Center
Frigidaire MLCE52RCS1 Frg(v1) / Laundry Center
Frigidaire MLCE52RCT0 Tap(v2) / Laundry Center
Frigidaire MLCE52RCT1 Frg(v2) / Laundry Center
Amana MLD510  Commercial Microwaves
Amana MLD510D  Commercial Microwaves
Maytag MLE15MNAGW Dryer - Ele
Maytag MLE15MNAYW Stacked Dryer - Electric
Maytag MLE15MNAZW Stacked Dryer - Electric
Maytag MLE15PDAGW Dryer - Ele
Maytag MLE15PDAUW Dryer - Ele
Maytag MLE15PDAYA Dryer - Ele
Maytag MLE15PDAYQ Dryer - Ele
Maytag MLE15PDAYW Dryer - Ele
Maytag MLE15PDAZW Stacked Dryer - Electric
Maytag MLE15PDBGW Dryer - Ele
Maytag MLE15PDCZW Stacked Dryer - Electric
Maytag MLE15PRAYW Stacked Dryer - Electric
Maytag MLE15PRAZW Stacked Dryer - Electric
Maytag MLE19PDAGW Dryer - Ele
Maytag MLE19PDAYW Stacked Laundry - Ele
Maytag MLE19PDAZW Stacked Laundry - Ele
Maytag MLE19PDCZQ Dryer - Ele
Maytag MLE19PDCZW Dryer - Ele
Maytag MLE19PDDGW Stacked Laundry - Ele
Maytag MLE19PDDYW Stacked Laundry - Ele
Maytag MLE19PNAUW Dryer - Ele
Maytag MLE19PNAYW Dryer - Ele
Maytag MLE19PNDYW Stacked Laundry - Ele
Maytag MLE19PRAYW Dryer - Ele
Maytag MLE19PRAZW Dryer - Ele
Maytag MLE19PRDYW Stacked Laundry - Ele
Maytag MLE2000AYW Stacked Laundry - Ele
Maytag MLE2000AZW Stacked Laundry - Ele
Maytag MLE23MNAUW Dryer - Ele
Maytag MLE23MNAYW Stacked Dryer - Electric
Maytag MLE23MNFYW Stacked Dryer - Electric
International MLE23PDAGW Dryer - Ele
Maytag MLE23PDAUW Dryer - Ele
Maytag MLE23PDAYQ Stacked Dryer - Electric
Maytag MLE23PDAYW Stacked Dryer - Electric
Maytag MLE23PDFGW Stacked Dryer - Electric
Maytag MLE23PDFUW Stacked Dryer - Electric
Maytag MLE23PDFYW Stacked Dryer - Electric
Maytag MLE23PDFZW Stacked Dryer - Electric
Maytag MLE23PDHGW Stacked Dryer - Electric
Maytag MLE23PDHYW Stacked Dryer - Electric
Maytag MLE23PDHZW Stacked Dryer - Electric
Maytag MLE23PRAYW Stacked Dryer - Electric
Maytag MLE23PRFYW Stacked Dryer - Electric
Maytag MLE23PRFZW Stacked Dryer - Electric
Frigidaire MLF303PGDA Frg(v1) / Gas Range
Frigidaire MLF303PGDC Frg(v1) / Gas Range
Frigidaire MLF303PGDD Frg(v2) / Gas Range
Frigidaire MLF303PGWA Frg(v2) / Gas Range
Frigidaire MLF303PGWC Frg(v3) / Gas Range
Frigidaire MLF303PGWD Frg(v4) / Gas Range
Frigidaire MLF311SGDA Frg(v1) / Gas Range
Frigidaire MLF311SGDC Frg(v1) / Gas Range
Frigidaire MLF311SGDD Frg(v1) / Gas Range
Frigidaire MLF311SGWA Frg(v2) / Gas Range
Frigidaire MLF311SGWC Frg(v2) / Gas Range
Frigidaire MLF311SGWD Frg(v2) / Gas Range
International MLG15MNAEW Dryer - Gas
Maytag MLG15MNAGW Dryer - Gas
Maytag MLG15MNAWW Stacked Dryer - Gas
International MLG15PDAEW Dryer - Gas
Maytag MLG15PDAGW Dryer - Gas
  #2 (permalink)
Old 08-03-2012, 05:24 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Take off the lower service panel and reach up on the right hand side. On the door lock mechanism you will find a tab which you can pull (gently) and release the door.
Start it up again and see if it works okay, otherwise use the tech notes inside the panel or under the top to do some testing.
__________________
  #3 (permalink)
Old 08-08-2012, 07:17 PM
Junior Member
Angry Maytag 2200
Trying to run diagnostics, door locks, Water runs cold first, hot second, when it gets to drum rotation for 30 seconds neither test works, gets to drain and seems to stick there, will drain water but will not go on to last test of spinning out.
Replaced control unit, same thing.
Thinking motor control board bad. Any ideas, does not show any trouble codes in test mode.
  #4 (permalink)
Old 08-09-2012, 04:54 AM
Senior Expert
APP Volunteer
Default
On these models it is usually one of the boards or the door lock mechanism that causes the problem you are having.
Unfortunately about the only way to diagnose it is to replace the parts. Fortunately if you buy from this site (no those of us who reply are not associated with the company) and you don't need the part you can return it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag front loader FH code tamiwalnut Washer Repair 4 04-19-2012 11:12 AM
Maytag Front Loader billyc714 Refrigerator & Freezer Repair 0 08-01-2011 01:25 PM
Maytag front loader red574 Dishwasher Repair 1 01-05-2009 04:15 PM
Maytag Neptune Front Loader pamela6308 Washer Repair 4 11-30-2008 12:25 PM
Maytag front loader LCooper Washer Repair 3 05-14-2008 06:46 PM
