Discuss
Whirlpool Top Load Clutch Repair?
 in
Washer Repair
My Whirlpool top load (direct drive) will not spin the bowl or agitate. The problem began with the bowl on
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Top Load Clutch Repair?
  #1 (permalink)
Old 08-02-2012, 07:39 AM
Junior Member
dabadoug is on a distinguished road
Default Whirlpool Top Load Clutch Repair?
Model Number: LSR5132PQ1   Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool top load (direct drive) will not spin the bowl or agitate. The problem began with the bowl on spinning every once in a while then progressed to not agitating. Based on the awesome videos this site provides, I found at the coupler is working fine and I can see the clutch housing spinning but the drive shaft does not spin for agitate or spin. I am thinking I need to replace the clutch but is there a way to check for sure? What else should I check before ordering the clutch to ensure this is the problem?
Thanks for the help and the great site!
Ads By Google
Related Models
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
Whirlpool LSR5132PQ4 Automatic Washer
Whirlpool LSR5132PQ4 AUTOMATIC WASHER
Whirlpool LSR5232DW0 AUTOMATIC WASHER
Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5232LQ1 AUTOMATIC WASHER
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0 Washers*
Whirlpool LSR5233EQ0 AUTOMATIC WASHER
Whirlpool LSR5233EQ1 DIRECT-DRIVE WASHER
Whirlpool LSR5233EQ2 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132BN0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW1 AUTOMATIC WASHER
Whirlpool LSR6132DQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132DZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132EQ0 AUTOMATIC WASHER
Whirlpool LSR6132EQ1 AUTOMATIC WASHER
Whirlpool LSR6132EZ0 AUTOMATIC WASHER
Whirlpool LSR6132EZ1 AUTOMATIC WASHER
Whirlpool LSR6132HQ0 AUTOMATIC WASHER
Whirlpool LSR6132HQ1 AUTOMATIC WASHER
Whirlpool LSR6132HZ0 AUTOMATIC WASHER
Whirlpool LSR6232JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR6232JQ1 WASHER - DIRECT DRIVE
Whirlpool LSR6232JQ2 AUTOMATIC WASHER
Whirlpool LSR6233BG0 AUTOMATIC WASHER
Whirlpool LSR6233BN0 AUTOMATIC WASHER
Whirlpool LSR6233BN1 WASHER
Whirlpool LSR6233BW0 AUTOMATIC WASHER
Whirlpool LSR6233BW1 WASHER
Whirlpool LSR6233DN0 AUTOMATIC WASHER
Whirlpool LSR6233DW0 AUTOMATIC WASHER
Whirlpool LSR6244AG0
Whirlpool LSR6244AN0
Whirlpool LSR6244AW0 Washers*
Whirlpool LSR6332KQ0 WASHER
Whirlpool LSR6332KQ1 AUTOMATIC WASHER
Whirlpool LSR6334LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR6334LQ1 AUTOMATIC WASHER
Whirlpool LSR6335LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR7010PQ0 AUTOMATIC WASHER
Whirlpool LSR7010PQ1 AUTOMATIC WASHER
Whirlpool LSR7010PQ2 AUTOMATIC WASHER
Whirlpool LSR7133KQ0 WASHER
Whirlpool LSR7133KQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ0 AUTOMATIC WASHER
Whirlpool LSR7133PQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ1 Automatic Washer
Whirlpool LSR7133PQ2 AUTOMATIC WASHER
Whirlpool LSR7200EQ0 AUTOMATIC WASHER
Whirlpool LSR7200EZ0 AUTOMATIC WASHER
Whirlpool LSR7233BG0
Whirlpool LSR7233BG1
Whirlpool LSR7233BG2
Whirlpool LSR7233BGO WASHER
Whirlpool LSR7233BN0
Whirlpool LSR7233BN1
Whirlpool LSR7233BN2
Whirlpool LSR7233BNO WASHER
Whirlpool LSR7233BQ0
Whirlpool LSR7233BQ1
Whirlpool LSR7233BQ2
Whirlpool LSR7233BQO WASHER
Whirlpool LSR7233BW0
Whirlpool LSR7233BW1
Whirlpool LSR7233BW2
Whirlpool LSR7233BWO WASHER
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0 WASHER
Whirlpool LSR7233DQ1 AUTOMATIC WASHER
Whirlpool LSR7233DW0 WASHER
Whirlpool LSR7233DZ0 WASHER
Whirlpool LSR7233DZ1 AUTOMATIC WASHER
Whirlpool LSR7233EQ0 WASHER
Whirlpool LSR7233EQ1 AUTOMATIC WASHER
Whirlpool LSR7233EW0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ1 AUTOMATIC WASHER
Whirlpool LSR7233HQ0 AUTOMATIC WASHER
Whirlpool LSR7233HZ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ1 AUTOMATIC WASHER
Whirlpool LSR7300PQ2 AUTOMATIC WASHER
Whirlpool LSR7333PQ0 AUTOMATIC WASHER
Whirlpool LSR7333PQ1 AUTOMATIC WASHER
Whirlpool LSR7333PQ3 AUTOMATIC WASHER
Whirlpool LSR7333PQ4 AUTOMATIC WASHER
Whirlpool LSR7333PQ4 Automatic Washer
Whirlpool LSR8010PQ0 AUTOMATIC WASHER
Whirlpool LSR8010PQ1 AUTOMATIC WASHER
Whirlpool LSR8010PQ2 AUTOMATIC WASHER
Whirlpool LSR8010PT0 AUTOMATIC WASHER
Whirlpool LSR8010PT1 AUTOMATIC WASHER
Whirlpool LSR8010PT2 AUTOMATIC WASHER
Whirlpool LSR8133HQ0 AUTOMATIC WASHER
Whirlpool LSR8133HZ0 AUTOMATIC WASHER
Whirlpool LSR8200EQ0 AUTOMATIC WASHER
Whirlpool LSR8200EZ0 AUTOMATIC WASHER
Whirlpool LSR8233EQ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EQ1 AUTOMATIC WASHER
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JQ1 WASHER
Whirlpool LSR8233JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JT1 WASHER
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
  #2 (permalink)
Old 08-03-2012, 05:20 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
If it is not agitating the clutch is not the problem. I think the problem is the coupling and unless you took the motor off and inspected it then I think you should do so.
The videos will show you how to do this.
__________________
  #3 (permalink)
Old 08-05-2012, 04:23 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I would remove the pump and motor. Turn the tranny coupler clockwise till spin engages. If very hard to turn, you have sticking brake shoes and probably a bad clutch.
__________________
  #4 (permalink)
Old 06-15-2013, 06:05 PM
Junior Member
ff_2111 is on a distinguished road
Default
Sounds like the coupler is broken near the shaft looks good on the outside but broken on the inside pull the motor and tranny out as one unit and then split them outside the unit. you don't even need to take the shell off the washer just lay it on its back........ to check the clutch .... once the unit is out hold the clutch cup firmly and try to spin the clutch band with your free hand if it slides it needs to be replaced.
  #5 (permalink)
Old 06-16-2013, 01:18 AM
Senior Expert
APP Volunteer
Default
The clutch usually wears out because the brake shoes are dragging.
You will need to take the outer cover off, the agitator also, and loosen the spanner nut on the spin basket. Just follow the info in my article "replacing direct drive washer brake shoes"
I never lay the washer on it's back, takes more work get the spin basket back in place.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool top load washer won't spin. replaced coupler and clutch kodiakmook Washer Repair 2 01-23-2012 05:11 AM
Whirlpool Top Load Washer Clutch Ring Retainer teddy99520 Washer Repair 3 03-12-2011 01:49 AM
Clutch adjustment A104 Top Load Maytag canonfodder Washer Repair 1 07-25-2010 12:27 PM
No power to Whirlpool Duet front load washer after bellow repair llm0283 Washer Repair 1 12-23-2009 01:52 PM
Ge Clutch Repair JTW Washer Repair 0 11-03-2008 06:26 PM
