Discuss
duet washer incoming water barely flowing
 in
Washer Repair
Yesterday the well guy installed a new well pump and he didn't bypass the home water softner before turning outside
Appliance Repair Forum > Appliance Repair Help > Washer Repair » duet washer incoming water barely flowing
  #1 (permalink)
Old 08-01-2012, 05:33 AM
Junior Member
blove6543 is on a distinguished road
Exclamation duet washer incoming water barely flowing
Brand: Whirlpool   Age: 1 - 5 years
Yesterday the well guy installed a new well pump and he didn't bypass the home water softner before turning outside facet on and let all the trashy water in the home at lowest point and that the basement where the 2009 duet washer is and when I by-passed the units after the fact...after HE already let the dirty water in. Well back to the washer...doing laundry last night I was turning it on and to start water filled washer with pressure for only maybe 5 seconds then the pressure was depleted more than half like it got stopped up.
My question is where do I start to get my washer unclogged? Then if incoming water lines to washer coming into washer is clear how do I see if the washer itself has a blockage? I restarted the washer again and now it has no pressure from the get-go. So im pretty sure somewhere there is a clog. Trust me I had to run clean water throughout the none to clean out the iron trash. Please help me find a solution because the well Guy took all my money...thanks for your help
Ads By Google
  #2 (permalink)
Old 08-01-2012, 11:46 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Clean out the screens in the water inlet valve and check also the inlet hoses. There may be screen in them too.
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Sport water flowing out of soap despencer#WFW8300SW05 jryan1122 Washer Repair 0 10-22-2011 04:33 AM
Incoming water dosn't shut off markstout1 Washer Repair 0 06-08-2008 08:49 PM
Incoming Water Won't Shut Off SYLVANIA Washer Repair 11 06-05-2008 05:43 AM
Incoming water won't shut off markstout1 Washer Repair 0 06-04-2008 09:58 PM
Incoming Water Won't Shut Off SYLVANIA Washer Repair 0 05-30-2008 08:05 AM
