| » Please Help!!!! |
Model Number: LTF7000ESO Brand: Frigidaire Age: 1 - 5 years
I have a Frigidaire LTF7000ESO in the spin cycle will not work. All other wash modes work normally, except at the end "spin mode", it will not spin. The drain works fine. In looking through some of the forums, I discovered a suggested diagnostic test. I ran the test and I am getting error code: 59
Could you please tell me what this code means and what part I would need to fix it. Thank you in advance for your help. Ads By Google Related Models |
Perform the test 10 as instructed in the Tech sheet (page 3) and post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire LTF7000ES0 Frigidaire/washer | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
You are welcome. We're glad you were able to fix it.
Thank you for the feedback. Gene.
__________________
Sorry about it. Try to perform the same test and post the results.
__________________
This error code leads to one of the most common problem with such washers: a bad door lock.
You can find more information in one of our previous threads: frigidaire washer won't spin out!! - The door lock assembly Part number: 131763202 Gene.
__________________
| Display Modes | |
