Discuss
ge washer makes lound grinding noise is spin cycle.
 in
Washer Repair
Machine works fine except for the loud jet noise in spin cycle. Related Models General Electric  S4200B2WW  Washer General Electric
Appliance Repair Forum > Appliance Repair Help > Washer Repair » ge washer makes lound grinding noise is spin cycle.
  #1 (permalink)
Old 01-28-2008, 05:59 AM
Junior Member
tater is on a distinguished road
Default ge washer makes lound grinding noise is spin cycle.
Model Number: S4200B2WW   Brand: GE   Age: 1 - 5 years
Related Models
General Electric S4200B3WW Washer
Roper S4257*0 SLIDE-IN GAS RANGE
Roper S4257W0 SLIDE-IN GAS RANGE
Roper S5007W0 Ranges, Electric*
Hoover S5083
General Electric S5100D0WW Washer
General Electric S5100D1WW Washer
Magic Chef S51FK-2KLX-64 RANGE- D/I CONT CLEAN GAS
Magic Chef S51FK-2KLX-ON RANGE- D/I CONT CLEAN GAS
General Electric S5200E1WW Washer
General Electric S5200E6WW Washer
Hoover S5501---
Hoover S5503---
Hoover S5507---
Hoover S5509---
Hoover S5509021
Hoover S5511---
Hoover S5513---
Hoover S5533---
Hoover S5535---
Hoover S5537---
Hoover S5539---
Hoover S5549
Hoover S5567011
Hoover S5569011
Hoover S5573--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5573011
Hoover S5573022
Hoover S5573033
Hoover S5575---
Hoover S5575001
Hoover S5577--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5579---
Hoover S5581---
Hoover S5583---
Hoover S5585---
Hoover S5587---
Hoover S5589---
Hoover S5593---
Hoover S5601--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5602070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5604070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5604080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5605 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5607---
Hoover S5609--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5610--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5610070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5610080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5613--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5615--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5619--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5620--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5620070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5625--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5626--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5627 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5627080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5630--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5635--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5636--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5639---
Hoover S5640--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5643--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5645---
Hoover S5645001
Hoover S5647---
Hoover S5649---
Hoover S5651---
Hoover S5655--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5668--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5669--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5671--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5672--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5673--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5673080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5674--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5675--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5675080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5676--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5677--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5678--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5680--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5682--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5684--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5684035 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5686--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5688--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5690--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5692--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5697--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5701--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5701035 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5703--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5709--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5711--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5713--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5715--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5716--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Magic Chef S58H-2CXW COOKING
Admiral S60STRP REF - SXS/I&W
Magic Chef S61HA-3KLX RANGE- S/I CONT CLEAN GAS
Admiral S61STRP REF - SXS/I&W
Magic Chef S64F-3CKX RANGE- S/C S/I GAS
Magic Chef S64F-3CKXW RANGE- S/C S/I GAS
Magic Chef S64F-3CKXW-NL RANGE- S/C S/I GAS
Magic Chef S64FA-3CKW RANGE- S/C S/I GAS
Magic Chef S64FN-3CKW RANGE- S/C S/I GAS
Magic Chef S64FN-3CKX RANGE- S/C S/I GAS
Magic Chef S64FN-3CKXW RANGE- S/C S/I GAS
Magic Chef S64FN-3CKXW-NL RANGE- S/C S/I GAS
Magic Chef S64H-4TKXW RANGE- S/C S/I GAS
Magic Chef S64HA-4TKXW RANGE- S/C S/I GAS
Roper S6507*0 SLIDE-IN RANGE
Roper S6507X0 SLIDE-IN RANGE
Hoover S6529--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S6530--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S6530600 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S6543--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
  #2 (permalink)
Old 01-28-2008, 01:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the drain pump for a foreign objects inside.
If there is nothing wrong then, most likely the problem is the transmission/breaks assembly.
- The part number for the drain pump is AP3193205
-The part number for the transmission/break assembly is AP2046402
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-04-2008, 03:49 PM
Junior Member
Jennie Ortega is on a distinguished road
Default
my washer is loud during the spin cycle but also the tub seems to be moving all around, did this happen to your washer as well?
  #4 (permalink)
Old 03-04-2008, 03:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jennie,
What is the complete model number of the washer?
Post it as a new thread, please.
__________________
  #5 (permalink)
Old 03-04-2008, 04:22 PM
Junior Member
Default
Im not sure if this is where the new thread goes but model number is lsq8243hqo
  #6 (permalink)
Old 03-04-2008, 04:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would do is remove the washer cabinet, remove the drain pump and check for a foreign objects inside the pump. Also check for a foreign objects between the inner and the outer tubs.
Check the suspension parts.
Here are the break down diagrams for the Whirlpool washer Model LSQ8243HQ0
__________________
  #7 (permalink)
Old 03-24-2008, 04:21 PM
Junior Member
Alan Kosanke is on a distinguished road
Cool
Quote:
Yes it does.
Alan
  #8 (permalink)
Old 03-24-2008, 05:57 PM
Senior Expert
APP Volunteer
bambiblaster is on a distinguished road
Default
To both... If these are new machines like within a year the spanner nuts have been coming loose on them and the basket itself is just flopping around in it.. Will need new spanner nuts and lock ring... and depending on ho long it ran a new basket
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer makes grinding noise. wont spin montanaJohn Washer Repair 6 02-16-2014 05:01 AM
spin cycle makes grinding noise, no spin jgungho Washer Repair 1 12-24-2009 09:28 AM
Washer makes grinding noise during spin vmart Dishwasher Repair 0 10-21-2009 07:11 PM
Whirlpool washer makes grinding noise on spin cycle reescup4 Washer Repair 5 09-03-2009 02:05 PM
Whirlpool Washer won't agitate or spin makes Grinding noise Lady Lee Washer Repair 4 03-25-2008 11:35 AM
