Discuss
Washtub will not fill but water is running
 in
Washer Repair
I have a stackable washer/drier. It normally works fine - cycling through the wash steps just fine. Every few washes
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washtub will not fill but water is running
  #1 (permalink)
Old 07-30-2012, 03:15 PM
Junior Member
js_pierce is on a distinguished road
Default Washtub will not fill but water is running
Brand: Whirlpool   Age: 5 - 10 years
I have a stackable washer/drier. It normally works fine - cycling through the wash steps just fine. Every few washes the washtub will not fill and the water continues to run. This can happen on the wash cycle or the rinse cycle. I am guessing that the pump is pumping water out during the fill step. Whatever the cause - the washtub does not fill and the water never gets above a few inches deep.
Any suggestions as to what is the problem or how to correct.
Ads By Google
  #2 (permalink)
Old 07-31-2012, 11:57 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the washer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-31-2012, 02:07 PM
Junior Member
Default
It will take me a day or so to get the MODEL number.
Thanks for your help
  #4 (permalink)
Old 08-01-2012, 05:21 AM
Junior Member
Default
FGX831CS1
This is the model number.....
  #5 (permalink)
Old 08-01-2012, 03:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the washer front panel and inspect all hoses inside. Use the washer without the front panel so you can see if the drain pump will run.
Here are the breakdown diagrams and Replacement parts for Frigidaire FGX831CS1 Frigidaire/laundry Center | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water wont stop running in the first fill and again at the rinse cycle Dadrocks40 Washer Repair 3 04-10-2011 05:43 AM
Water wont stop running in the first fill and again at the rinse cycle Dadrocks40 Washer Repair 0 03-27-2011 08:32 PM
Water running loading and draining but wash cycle isn't running maree Dishwasher Repair 0 01-09-2011 06:56 PM
Anyone know the size of the washtub? Bluejay Washer Repair 0 06-21-2010 04:57 PM
Washer continuously drains w/ water running after rinse fill HSquare Washer Repair 1 01-14-2009 06:44 PM
