Discuss
Stops Spinning on high Spin
 in
Washer Repair
Whirlpool Ultimate care II agitates spin on low but as soon as it kick to high speed spin it stops
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Stops Spinning on high Spin
  #1 (permalink)
Old 07-29-2012, 05:16 PM
Junior Member
gbyrd34 is on a distinguished road
Default Stops Spinning on high Spin
Model Number: LS86300PW2   Brand: Whirlpool   Age: 1 - 5 years
Whirlpool Ultimate care II agitates spin on low but as soon as it kick to high speed spin it stops spinning altogether. Model # Should be LSB6300pw2
Ads By Google
Related Models
Whirlpool LSA3340W0
Whirlpool LSA3340W7
Whirlpool LSA3340W8
Whirlpool LSA7800W1
Whirlpool LSA7804W1
Whirlpool LSA7805W1
Whirlpool LSA7809W1
Whirlpool LSB4640W0
Whirlpool LSB6000LQ0
Whirlpool LSB6000PQ0 Automatic Washer
Whirlpool LSB6000PQ1 Automatic Washer
Whirlpool LSB6000PQ2 Automatic Washer
Whirlpool LSB6200KQ0
Whirlpool LSB6200KQ1 Automatic Washer
Whirlpool LSB6200PQ0 Automatic Washer
Whirlpool LSB6200PQ1 Automatic Washer
Whirlpool LSB6200PQ2 Automatic Washer
Whirlpool LSB6300LQ0
Whirlpool LSB6300LW0
Whirlpool LSB6300LW1 Automatic Washer
Whirlpool LSB6300LW2 Automatic Washer
Whirlpool LSB6300LW3 Automatic Washer
Whirlpool LSB6300PW0 Automatic Washer
Whirlpool LSB6300PW1 Automatic Washer
Whirlpool LSB6300PW3 Automatic Washer
Whirlpool LSB6300PW4 Automatic Washer
Whirlpool LSB6400KQ0
Whirlpool LSB6400KQ1
Whirlpool LSB6400LW0
Whirlpool LSB6400LW1 Automatic Washer
Whirlpool LSB6500PW0 Automatic Washer
Whirlpool LSB6500PW1 Automatic Washer
Whirlpool LSB6500PW2 Automatic Washer
Whirlpool LSB6500PW3 Automatic Washer
Whirlpool LSB6500PW4 Automatic Washer
Whirlpool LSC5000PQ0 Automatic Washer
Whirlpool LSC5000PQ1 Automatic Washer
Whirlpool LSC5000PQ2 Automatic Washer
Whirlpool LSC6244AN0
Whirlpool LSC6244AQ0
Whirlpool LSC6244AW0
Whirlpool LSC6244AZ0
Whirlpool LSC6244BN0
Whirlpool LSC6244BQ0
Whirlpool LSC6244BW0
Whirlpool LSC6244BZ0
Whirlpool LSC8244BG0
Whirlpool LSC8244BG1
Whirlpool LSC8244BN0
Whirlpool LSC8244BN1
Whirlpool LSC8244BQ0
Whirlpool LSC8244BQ1
Whirlpool LSC8244BW0
Whirlpool LSC8244BW1
Whirlpool LSC8244BZ0
Whirlpool LSC8244BZ1
Whirlpool LSC8244DQ0
Whirlpool LSC8244DZ0
Whirlpool LSC8244EQ0
Whirlpool LSC8244EQ1
Whirlpool LSC8244EZ0
Whirlpool LSC8244EZ1
Whirlpool LSC8245AN0
Whirlpool LSC8245AQ0
Whirlpool LSC8245AW0
Whirlpool LSC8245BN0
Whirlpool LSC8245BW0
Whirlpool LSC9000PW0 Automatic Washer
Whirlpool LSC9000PW1 Automatic Washer
Whirlpool LSC9000PW2 Automatic Washer
Whirlpool LSC9245BN0
Whirlpool LSC9245BN1
Whirlpool LSC9245BQ0
Whirlpool LSC9245BQ1
Whirlpool LSC9245BW0
Whirlpool LSC9245BW1
Whirlpool LSC9245BZ0
Whirlpool LSC9245BZ1
Whirlpool LSC9355AG0
Whirlpool LSC9355AN0
Whirlpool LSC9355AW0
Whirlpool LSC9355BN0
Whirlpool LSC9355BN1
Whirlpool LSC9355BQ0
Whirlpool LSC9355BQ1
Whirlpool LSC9355BW0
Whirlpool LSC9355BW1
Whirlpool LSC9355BZ0
Whirlpool LSC9355BZ1
Whirlpool LSC9355DQ0
Whirlpool LSC9355DZ0
Whirlpool LSC9355EQ0
Whirlpool LSC9355EQ1
Whirlpool LSC9355EZ0
Whirlpool LSC9355EZ1
Admiral LSD2615HEB Ref - SXS/I&W
Admiral LSD2615HEW Ref - SXS/I&W
Admiral LSD2615HEZ Ref - SXS/I&W
Maytag LSE1000 Stacked Laundry - Ele
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W Stacked Laundry - Ele
Jenn-Air LSE2700W-8 Stacked Laundry - Ele
Jenn-Air LSE2700W-C Stacked Laundry - Ele
Jenn-Air LSE2704W Stacked Laundry - Ele
Jenn-Air LSE2704W-8 Stacked Laundry - Ele
Maytag LSE7800 Stacked Laundry - Ele
Maytag LSE7800ACE Stacked Laundry - Ele
Maytag LSE7800ACL Stacked Laundry - Ele
Maytag LSE7800ACW Stacked Laundry - Ele
Maytag LSE7800ADE Stacked Laundry - Ele
Maytag LSE7800ADL Stacked Laundry - Ele
Maytag LSE7800ADW Stacked Laundry - Ele
Maytag LSE7800AEE Stacked Laundry - Ele
Maytag LSE7800AEL Stacked Laundry - Ele
Maytag LSE7800AEW Stacked Laundry - Ele
International LSE7800AGE Stacked Laundry - Ele
International LSE7800AGL Stacked Laundry - Ele
Maytag LSE7804ACE Stacked Laundry - Ele
Maytag LSE7804ACL Stacked Laundry - Ele
Maytag LSE7804ACM Stacked Laundry - Ele
  #2 (permalink)
Old 07-29-2012, 05:21 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
I can't find any info on the model number you posted, is it correct?
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 07-29-2012, 05:59 PM
Junior Member
Default
model s/b LSB6300PW2
  #4 (permalink)
Old 07-29-2012, 06:02 PM
Senior Expert
APP Volunteer
Default
Could be a bad connection on the wire harness were it plugs into the motor.
If that looks ok then I would have to start troubleshooting with a multimeter and wiring diagram as it could be a bad motor or timer.
__________________
  #5 (permalink)
Old 08-09-2012, 12:37 PM
Junior Member
Default
Thank You, I checked wiring and then I noticed it was making a little noise as if it was trying to run, found a test for the clutch, it was getting hot so I changed it and it seems to be running fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spinning stops and starts DavieJones Washer Repair 1 12-25-2011 12:43 PM
High Speed Spin Starts than stops orprepus Washer Repair 2 03-02-2011 10:07 PM
washer makes a high pitched squeal when spinning ljmacneill Washer Repair 1 08-21-2009 04:36 AM
Dryer stops spinning Melucci Dryer Repair 0 12-03-2007 08:51 AM
Dryer stops before loads are dry,esp on High setting azhorn Dryer Repair 2 08-02-2007 03:05 PM
