| » Roper top-load washer basket/tub won't spin |
Model Number: RAS7133RQ0 Brand: Roper Age: 1 - 5 years
The washer works fine when washing, but will not spin in spin cycle. I ahve pulled the motor coupling and it looks to be in good shape. When I tilt the machine back, I can see the drive shaft is turning the drum below the brake drum. I'm guessing this is the clutch. So, I'm thinking my problem is somewhere above the clutch to the tub or the clutch itself. I also have a leaky water pump. That's an easy one. Is there a drawing of how this thing is assembled somewhere I can get. I have not pulled the tub and agitator yet to check the spindle on the drive shaft or the drive block yet.
Probably a clutch issue (and check the brakes while you are in there).
Here is the part with the video of how to replace it. Part number: AP3094537 and if you click on your model number you get taken to exploded views of your machine.
__________________
| Display Modes | |
| Roper top load washer shakes violently...HELP. | Hexster | Washer Repair | 5 | 08-30-2011 02:05 AM |
| Roper Top Load Washer fills slowly | dougdawn707 | Washer Repair | 1 | 03-09-2010 05:35 AM |
| Whirlpool washer basket won't spin | mft7 | Washer Repair | 1 | 09-06-2009 03:07 PM |
| Roper washer will not spin with a full load | DRobison | Washer Repair | 0 | 03-13-2009 11:48 AM |
| Roper Top Load Washer Stops Mid Cycle | wisfamily | Washer Repair | 7 | 11-01-2008 06:52 PM |
