Discuss
Is the motor coupling the problem in my washer?
 in
Washer Repair
I have a kitchenaid washer that was given to us a few weeks ago. It was working fine until this
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Is the motor coupling the problem in my washer?
  #1 (permalink)
Old 07-29-2012, 11:23 AM
Junior Member
skydragon is on a distinguished road
Default Is the motor coupling the problem in my washer?
Model Number: kawet900   Brand: Kitchen Aid   Age: 5 - 10 years
I have a kitchenaid washer that was given to us a few weeks ago. It was working fine until this last week when I pulled the clothes out and the barrel had a little bit of water left in it. I ran it again and it filled and started but very quickly made horrible noises and would not finish washing but but kept running. WHen I put a screw driver to keep the lid switch locked while having the lid open I started to run it empty, if you put it on the spin cycle all the water does drain out fine but it does not spin at all. We took a look at the motor couplings last night and they are three pronged circles. The rubber peice was in one peice but had an extremely thin spot on the outer edge of the hole that goes over one prong, all the prongs are in one peice and there is rubber shavings in the area but no chunks. Everything I have read and looked up seems to say its this part, right down to the sound and slight rubber burning smell. But as far as I can tell the only peice with wear is the rubber middle piece but it does not look that bad but it also does not seem to stay in place either. Currently the motor is out and we cant get it back in but thats okay right now sense I think we need to get a new motor coupler. Am I on the right track that this is the problem or should we keep digging? About to have my 3rd kiddo so I need to get this up and running fast.
Ads By Google
Related Models
Whirlpool KAWL400WAL0
Whirlpool KAWL400WAL1
Whirlpool KAWL400WWH0
Whirlpool KAWL400WWH1
Whirlpool KAWL410BAL0
Whirlpool KAWL410BWH0
Whirlpool KAWL410BWH1
Whirlpool KAWL500WAL0
Whirlpool KAWL500WWH0
Whirlpool KAWL510BAL0
Whirlpool KAWL510BWH0
Whirlpool KAWL517BWH0
Whirlpool KAWL517BWH1
Whirlpool KAWS577EQ0
Whirlpool KAWS577EZ0
Whirlpool KAWS677EQ0
Whirlpool KAWS677EZ0
Whirlpool KAWS700EQ0
Whirlpool KAWS700EZ0
Whirlpool KAWS700GQ0
Whirlpool KAWS700GT0
Whirlpool KAWS700GZ0
Whirlpool KAWS700JQ0
Whirlpool KAWS700JQ1
Whirlpool KAWS700JQ2
Whirlpool KAWS700JQ3
Whirlpool KAWS700JQ4
Whirlpool KAWS700JT0
Whirlpool KAWS700JT1
Whirlpool KAWS700JT2
Whirlpool KAWS700JT3
Whirlpool KAWS700JT4
Whirlpool KAWS700LQ0
Whirlpool KAWS700LT0
Whirlpool KAWS750GQ0
Whirlpool KAWS750GQ1
Whirlpool KAWS750GT1
Whirlpool KAWS750GZ0
Whirlpool KAWS750GZ1
Whirlpool KAWS750JQ0
Whirlpool KAWS750JQ1
Whirlpool KAWS750JQ2
Whirlpool KAWS750JQ3
Whirlpool KAWS750JQ4
Whirlpool KAWS750JT0
Whirlpool KAWS750JT1
Whirlpool KAWS750JT2
Whirlpool KAWS750JT3
Whirlpool KAWS750JT4
Whirlpool KAWS750LQ0 Automatic Washer
Whirlpool KAWS750LQ1 Automatic Washer
Whirlpool KAWS750LQ2 Automatic Washer
Whirlpool KAWS750LQ3 Automatic Washer
Whirlpool KAWS750LQ4 Automatic Washer
Whirlpool KAWS750LT0 Automatic Washer
Whirlpool KAWS750LT1 Automatic Washer
Whirlpool KAWS750LT2 Automatic Washer
Whirlpool KAWS750LT3 Automatic Washer
Whirlpool KAWS750LT4 Automatic Washer
Whirlpool KAWS777EQ0
Whirlpool KAWS777EZ0
Whirlpool KAWS800GQ0
Whirlpool KAWS800GQ1
Whirlpool KAWS800GZ0
Whirlpool KAWS800GZ1
Whirlpool KAWS850GQ0
Whirlpool KAWS850GQ1
Whirlpool KAWS850GT0
Whirlpool KAWS850GT1
Whirlpool KAWS850GZ0
Whirlpool KAWS850GZ1
Whirlpool KAWS850JQ0
Whirlpool KAWS850JQ1
Whirlpool KAWS850JQ2
Whirlpool KAWS850JQ3
Whirlpool KAWS850JQ4
Whirlpool KAWS850JT0
Whirlpool KAWS850JT1
Whirlpool KAWS850JT2
Whirlpool KAWS850JT3
Whirlpool KAWS850JT4
Whirlpool KAWS850LE0
Whirlpool KAWS850LE1 Automatic Washer
Whirlpool KAWS850LE2 Automatic Washer
Whirlpool KAWS850LQ0
Whirlpool KAWS850LQ1 Automatic Washer
Whirlpool KAWS850LQ2 Automatic Washer
Whirlpool KAWS850LT0
Whirlpool KAWS850LT1 Automatic Washer
Whirlpool KAWS850LT2 Automatic Washer
Whirlpool KAWS855JE0
Whirlpool KAWS855JE1
Whirlpool KAWS855JE2
Whirlpool KAWS855JE3
Whirlpool KAWS855JE4
Whirlpool KAWS977EQ0
Whirlpool KAWS977EZ0
Bosch KB030-062
Bosch KB032-062
Bosch KB035-062
Bosch KB036-062
Bosch KB090-054
Bosch KB091-054
Bosch KB100-046
Frigidaire KB122G0 Wwh(v1) / Built - in Oven
Frigidaire KB122G1 Wwh(v2) / Built - in Oven
Frigidaire KB122G2 Wwh(v3) / Built - in Oven
Frigidaire KB122G3 Wwh(v4) / Built - in Oven
Frigidaire KB122G4 Wwh(v5) / Built - in Oven
Frigidaire KB122LM0 Wwh(v1) / Wall Oven
Frigidaire KB122LM1 Wwh(v2) / Wall Oven
Frigidaire KB122LM2 Wwh(v1) / Wall Oven
Frigidaire KB122LMO Wwh(v1) / Wall Oven
Frigidaire KB152LM0 Wwh(v1) / Electric Range
Frigidaire KB152LM1 Wwh(v1) / Electric Range
Frigidaire KB152LM2 Wwh(v1) / Electric Range
Whirlpool KB26G1X-3 6 Qt. Stand Mixer
Whirlpool KB26G1XAC3 6 Qt. Stand Mixer
Whirlpool KB26G1XAC5 6 Qt. Stand Mixer
Whirlpool KB26G1XBU3 6 Qt. Stand Mixer
  #2 (permalink)
Old 07-29-2012, 12:00 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
I could not find any information on the model number you posted.
Is the center of the motor coupling stripped out?
Should have two flat sides like the motor shaft.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 07-29-2012, 12:18 PM
Junior Member
Default
I am honestly not sure how it is supposed to look to begin with. I know that the two plastic peices (one on transmission side and one on motor side) still have the pegs on and do not look damaged (I think) the rubber peice that goes between the two has some worn spots and does not appear to stay in place once the machine is started and it seems that the holes in the rubber that the pegs on the two plastic peices go into are now too big to stay in place correctly once the machine is running. Everything else looks good. Near as I can tell you can use the replacement parts made by whirlpool for this model but I can not find the model number anywhere either. It was sitting unused for a long time before we got it and was working fine until this started. The sound and behavior matches all videos and comments related to the motor couplings but I don't have a good refernce point as to what they should look like when it is not the problem. The area that these peice are in is coated in new rubber shavings and it is clear that the rubber peice is worn out some and weakend on the outer edges and the holes are stretched.
  #4 (permalink)
Old 07-29-2012, 12:25 PM
Senior Expert
APP Volunteer
Default
A new motor coupling looks like this.
Part number: 285753A
__________________
  #5 (permalink)
Old 07-29-2012, 12:47 PM
Junior Member
Default
In this video the coupler peices are circle like the current ones are. The new ones in the video clearly fit together tighter than what is in now. I am thinking it is atleast worth a shot for the price and it does appear that this part is currently worn enough to atleast need to be replaced soon if it is not the problem. I am unsure of what other source the problem could be than this. I must admit washers are not my forte as far as repairing goes. Sinks and the like I can do no problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Motor coupling Moxleysr Washer Repair 4 03-25-2011 11:22 AM
Whirlpool washer motor coupling Admin / APP Team Appliance Parts 0 09-04-2009 11:58 PM
washer motor coupling flewis46@comcast.net Washer Repair 1 03-26-2008 03:07 AM
Changing motor coupling on washer abbylou22 Washer Repair 2 01-21-2008 06:39 PM
new motor coupling doesn't seem to fit wdunkin Washer Repair 1 12-29-2007 08:33 AM
