| » Cold water fills slowly |
There are two screens inside the water inlet valve that may need to be cleaned. If the screens are clean then I would replace the water valve.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
I would remove the cold water hose from the washer and run it into a pail to check it's flow.
Some hoses have a screen filter built into the rubber washer at the faucet end, also hoses can de-laminate internally and reduce the flow. If the flow is good then as ApplianceJunk said look into the washer valve's input and check the screen filter. If dirty clean it. Do not permanently remove it as it is there to keep crud out of the valve, which could hold the valve open and cause a flood.
__________________
| Display Modes | |
| My washer fills so slowly with cold water & stops before rinse cycle | JennH | Washer Repair | 6 | 07-29-2012 10:20 AM |
| Kenmore Washer Cold Water Dispenses Slowly | Bill L | Washer Repair | 1 | 06-17-2011 03:02 AM |
| washer only fills up with cold water | dancergirl | Washer Repair | 1 | 02-25-2011 03:02 PM |
| Dishwasher slowly fills with with water when not in use | billkjones | Dishwasher Repair | 1 | 12-13-2010 05:30 AM |
| Cold water fills very slow | dreyn | Washer Repair | 1 | 07-13-2009 03:58 PM |
