| » Roper Washer stopped during cycle |
Model Number: Unknown Brand: Roper Age: 5 - 10 years
This afternoon my wife was running a small load of laundry and the washer stopped working sometime during the spin cycle. There was a hot electrical smell; not a burning electrical smell, just hot. I loosened the back plate and removed the cabinet. Mounted to the back plate is a capacitor which was quite warm and leaking an oily substance from the bottom. As I was disassembling the machine, I heard a click like a thermal switch resetting. The motor was quite hot. Motor turns freely; transmission turns freely as well. No obvious signs of any heat damage. No signs of burning on any wiring or on/in the motor. Question is: could a faulty capacitor cause these issues? What else should I check?
Additional info: 10 yrs experience in Aviation electronics so can definitely work my way through a schematic. Quite mechanically adept and not afraid to wade into a repair. 3 weeks ago the house heat pump unit went out. The outside fan was very hot and the compressor refused to run. The repairman found a failed run-capacitor. So this is why I asked about the faulty capacitor above. Ads By Google Related Models |
| Display Modes | |
| Roper Washer won't advance cycle | ODog | Washer Repair | 4 | 10-20-2011 09:30 AM |
| Roper washer spins on rinse cycle but not on spin cycle | Swica | Washer Repair | 4 | 03-07-2011 05:23 PM |
| Roper washer won't complete cycle | R&S123 | Washer Repair | 6 | 03-11-2010 02:26 PM |
| doesn't always spin cycle Roper Washer | kalahiki | Washer Repair | 8 | 07-12-2009 03:41 PM |
| Roper Top Load Washer Stops Mid Cycle | wisfamily | Washer Repair | 7 | 11-01-2008 06:52 PM |
