Discuss
whirlpool Duet washer control panel lights flicker then stop
 in
Washer Repair
During a normal wash cycle, at any stage, the control panel lights will flicker and then the cycle stops with
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool Duet washer control panel lights flicker then stop
  #1 (permalink)
Old 07-27-2012, 11:18 AM
Junior Member
lsilva813 is on a distinguished road
Default whirlpool Duet washer control panel lights flicker then stop
Brand: Whirlpool   Age: 5 - 10 years
During a normal wash cycle, at any stage, the control panel lights will flicker and then the cycle stops with the time remaining display blinking. It acts as though the Pause button was pressed. I am able to press start and it resumes only to randomly do the same thing 1 or 2 or 10 minutes later. Occassionally, the flickering lights are followed by a complete shut down where I have to start the cycle all over or select to begin at a later stage (rince or spin...).
Ads By Google
  #2 (permalink)
Old 07-28-2012, 05:04 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
These Duets are very difficult to diagnose. Look inside the lower service panel and under the top for tech notes, but the most likely problem is that your main control board is shot. See if the tests will confirm that.
__________________
  #3 (permalink)
Old 08-01-2012, 05:02 AM
Junior Member
Default Problem solved
After openning the top to start investigating, I discovered the ribbon wire had fallen down on top of the drum where it was constantly being rubben the wrong way against the concrete counter weight on the drum. This caused the plastic wire coating to wear off and eventually severed the one of the wires. I was able to repair, electrical tape wrap, and place the ribbon back in the clips. Works great again.
  #4 (permalink)
Old 08-01-2012, 05:56 AM
Senior Expert
APP Volunteer
Default
Well great, glad you found that easy fix and thanks for the update.
Good luck with the washer going forward.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool duet dryer control panel lights up mfusonduet Dryer Repair 1 01-26-2012 05:46 PM
Whirlpool Duet Control Panel dontno2much Washer Repair 13 04-12-2011 11:20 AM
no lights on front control panel- duet washer cheddardip Washer Repair 2 08-14-2010 08:13 AM
Kenmore HE4t (Whirlpool Duet) washer control panel shows sahed lines WJerry Washer Repair 0 02-28-2009 03:14 PM
how to get control panel off of whirlpool duet washer danica Washer Repair 1 12-08-2008 11:32 AM
