| » Kenmore will not pump water out |
Model Number: 110.22722100 Brand: Kenmore Age: 1 - 5 years
All cycles work until it is time to rinse where the water is pumped to the drain. Manually pump it out possible to do the laundry. Appreciate some insight and also where a manual may be found. Thanks. Likely very important, washer used to work somewhat fine as is plugged into a GFI and would pop out when the rinse/drain started, reset GFI and eventually get through the entire cycle, plugged into a regular outlet 20a and worked fine a few times and then this issue.
Ads By Google Related Models Last edited by funday : 07-27-2012 at 09:23 AM. |
Hi.
Open the control panel check the continuity between two outer wires at the lid switch plug. with the lid closed you should read continuity. No continuity - replace the lid switch Part number: 3949238 Use the video clip for disassembling instructions. Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Simon, your reply is unbeatable, the video makes this job exceptionally easy.
while I am heavily trained in construction as a PM over huge projects, this washer issue would have ended in being junked, myself flipping out in attempting it and requiring a 12 pack to calm down. Count on any issues I have and the parts needed coming from your business. Thanks I truly appreciate a professional who is a real professional. DWC |
Thank you. I'm blushing.
Simon.
__________________
| Display Modes | |
| Kenmore ultrawash model fills but wont pump water | mike brown | Dishwasher Repair | 0 | 01-18-2012 05:12 AM |
| Kenmore dishwasher motor won't pump water out | astro3ron | Dishwasher Repair | 5 | 09-03-2010 10:39 AM |
| Kenmore leaking and screeching water pump/valve? | snowman3 | Refrigerator & Freezer Repair | 0 | 01-26-2010 10:15 PM |
| Kenmore Washer gushing water from bottom, Can the pump be the problem? | fancinan@comcast.net | Washer Repair | 3 | 04-17-2008 08:34 AM |
| sock stuck in water pump... do i need a new pump? | volcompunker82 | Washer Repair | 0 | 03-08-2008 07:20 PM |
