| » Washer Stops on Fill Cycle |
Model Number: 22912 Brand: Kenmore Age: 5 - 10 years
I had some plumbing work done in my basement of the water pipes. When I went to do a wash, right at start-up it sputtered (air in the line) and then continued to flow. After that it would stop flowing every 30 seconds and would only start flowing again when I shut the machine of and then started it again. I had to do it about 4-5 times to get the wash cycle started. The rinse cycle worked fine.
After the wash completed, I started directly on the Rinse cycle and it worked fine. Any suggestions would be most appreciated. Ads By Google Related Models |
I am guessing that you are washing on the hot cycle and rinsing on the cold cycle. In that case check the inlet valve for some obstruction, and if it is clar try replacing the inlet valve. First use a meter to make sure voltage is getting to the inlet valve continuously.
__________________
| Display Modes | |
| washer starts to fill then stops | richie33 | Dishwasher Repair | 2 | 11-03-2011 08:32 PM |
| estate washer fill then stops | sandyn | Washer Repair | 0 | 09-21-2011 03:58 PM |
| Washer will fill but stops | mrack | Washer Repair | 4 | 11-28-2010 09:30 PM |
| GE Washer Will Only Fill with Water..then stops! | countryfolk | Washer Repair | 1 | 03-20-2009 04:02 AM |
| Stops 3/4 through fill on rinse cycle | jamman | Washer Repair | 3 | 03-15-2009 10:18 AM |
