| » Washer moves during spin cycle and comes to violent stop. |
Model Number: KAWS750GQ1 Brand: Kitchen Aid Age: 5 - 10 years
I was going to replace the 4 springs, suspension pads and tub suspension pads. If the brakes are faulty, should I try lubricating the brakes between the brake coil spring and the inside of the drum. If so, which lubricant should I use?
If it is a brake problem, how do I know whether it is the shoes, or brake assembly? Does the brake assembly come with the shoes? Have I considered everything? Please respond, I need to get the parts ordered today. Ads By Google Related Models |
You probably have bad brake shoes. Go to my stickey above "replacing direct drive washer brake shoes" for info. You will need to buy the special spanner wrench to loosten the drive block nut.
__________________
| Display Modes | |
| Maytag Washer Moves Across Floor on Spin Cycle | carmicfg | Washer Repair | 12 | 02-28-2013 01:33 AM |
| Maytag mav8000aww - violent off center during spin cycle... | ScottCypress | Washer Repair | 9 | 09-02-2011 01:58 AM |
| Violent spin cycle | greywolf94 | Washer Repair | 2 | 02-10-2011 12:00 PM |
| violent stop on spin cycle | dirtguy | Washer Repair | 1 | 05-19-2009 02:11 PM |
| New frontload washer moves all over the place on spin cycle | alemap68 | Washer Repair | 0 | 12-04-2008 04:53 PM |
