Discuss
Whirlpool washer fills with water then nothing
 in
Washer Repair
I had an issue with the agitator awhile back and had to replace the coupling, in the process of replacing
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer fills with water then nothing
  #1 (permalink)
Old 07-25-2012, 06:57 AM
Junior Member
micha219 is on a distinguished road
Default Whirlpool washer fills with water then nothing
Model Number: LSN1000KQ0   Brand: Whirlpool   Age: 1 - 5 years
I had an issue with the agitator awhile back and had to replace the coupling, in the process of replacing the body, I broke one of the tabs on the vacuum break, where the water fills the tub. It hasn't been a problem until yesterday. we had moved the washer and when my wife went to use the machine, apparently, this part fell into the tub and caused it to jam. We noticed it because of a burnt smell coming from the machine. It is filled with water but will do nothing else. The timer makes a noise whenever it is set to any other position, i.e. spin, rinse, etc. I checked the continuity of the lid switch, its good. My question is; what is the most likely culprit? The start capacitor or the motor? Or could it be something else? Any suggestions on what I should check without spending money on parts by replacing them until I find which it is. Thanks
Ads By Google
Related Models
Whirlpool LSN1000KQ0
Whirlpool LSN1000KT0
Whirlpool LSN1000LG0
Whirlpool LSN1000LG1 Automatic Washer
Whirlpool LSN1000LG2 Automatic Washer
Whirlpool LSN1000LG3 Automatic Washer
Whirlpool LSN1000LW0
Whirlpool LSN1000LW1 Automatic Washer
Whirlpool LSN1000LW2 Automatic Washer
Whirlpool LSN1000LW3 Automatic Washer
Whirlpool LSN1000PQ0 Automatic Washer
Whirlpool LSN1000PQ1 Automatic Washer
Whirlpool LSN1000PQ2 Automatic Washer
Whirlpool LSN1000PQ3 Automatic Washer
Whirlpool LSN2000JQ0
Whirlpool LSN2000JQ1
Whirlpool LSN2000JQ2
Whirlpool LSN2000JT0
Whirlpool LSN2000JT1
Whirlpool LSN2000JT2
Whirlpool LSN2000LG0
Whirlpool LSN2000LG1 Automatic Washer
Whirlpool LSN2000LW0
Whirlpool LSN2000LW1 Automatic Washer
Whirlpool LSN2000PG0 Automatic Washer
Whirlpool LSN2000PG1 Automatic Washer
Whirlpool LSN2000PG2 Automatic Washer
Whirlpool LSN2000PG3 Automatic Washer
Whirlpool LSN2000PG4 Automatic Washer
Whirlpool LSN2000PW0 Automatic Washer
Whirlpool LSN2000PW1 Automatic Washer
Whirlpool LSN2000PW2 Automatic Washer
Whirlpool LSN2000PW3 Automatic Washer
Whirlpool LSN2000PW4 Automatic Washer
Whirlpool LSN3000PG0 Automatic Washer
Whirlpool LSN3000PG1 Automatic Washer
Whirlpool LSN3000PG2 Automatic Washer
Whirlpool LSN3000PG3 Automatic Washer
Whirlpool LSN3000PG4 Automatic Washer
Whirlpool LSN3000PW0 Automatic Washer
Whirlpool LSN3000PW1 Automatic Washer
Whirlpool LSN3000PW2 Automatic Washer
Whirlpool LSN3000PW3 Automatic Washer
Whirlpool LSN3000PW4 Automatic Washer
Whirlpool LSN7233BN0
Whirlpool LSN7233BN1
Whirlpool LSN7233BQ0
Whirlpool LSN7233BQ1
Whirlpool LSN7233BW0
Whirlpool LSN7233BW1
Whirlpool LSN7233DQ0
Whirlpool LSN7233DW0
Whirlpool LSN8244AN0
Whirlpool LSN8244AQ0
Whirlpool LSN8244AW0
Whirlpool LSN8244BN0
Whirlpool LSN8244BQ0
Whirlpool LSN8244BW0
Whirlpool LSP6244AG0
Whirlpool LSP6244AN0
Whirlpool LSP6244AW0
Whirlpool LSP6244BG0
Whirlpool LSP6244BN0
Whirlpool LSP6244BW0
Whirlpool LSP8244BG0
Whirlpool LSP8244BG1
Whirlpool LSP8244BN0
Whirlpool LSP8244BN1
Whirlpool LSP8244BW0
Whirlpool LSP8244BW1
Whirlpool LSP8245AN0
Whirlpool LSP8245AW0
Whirlpool LSP8245BN0
Whirlpool LSP8245BW0
Whirlpool LSP9245BN0
Whirlpool LSP9245BN1
Whirlpool LSP9245BW0
Whirlpool LSP9245BW1
Whirlpool LSP9355AG0
Whirlpool LSP9355AN0
Whirlpool LSP9355AW0
Whirlpool LSP9355BN0
Whirlpool LSP9355BN1
Whirlpool LSP9355BW0
Whirlpool LSP9355BW1
Whirlpool LSQ7030KQ0
Whirlpool LSQ7030LQ0
Whirlpool LSQ7030LT0
Whirlpool LSQ7030MQ0 Automatic Washer
Whirlpool LSQ7533JQ0
Whirlpool LSQ7533JQ1
Whirlpool LSQ7533JT0
Whirlpool LSQ7533JT1
Whirlpool LSQ8000HQ0
Whirlpool LSQ8000JQ0
Whirlpool LSQ8000JQ1
Whirlpool LSQ8000LQ0
Whirlpool LSQ8000LQ1 Automatic Washer
Whirlpool LSQ8000LQ2 Automatic Washer
Whirlpool LSQ8000LQ3 Automatic Washer
Whirlpool LSQ8200HQ0
Whirlpool LSQ8200HZ0
Whirlpool LSQ8220HQ0
Whirlpool LSQ8243HQ0
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
Whirlpool LSQ8500JQ2
Whirlpool LSQ8500JT0
Whirlpool LSQ8500JT1
Whirlpool LSQ8500JT2
Whirlpool LSQ8500LQ0 Automatic Washer
Whirlpool LSQ8510LQ0 Automatic Washer
Whirlpool LSQ8511KQ0
Whirlpool LSQ8511KT0
Whirlpool LSQ8512KQ0
Whirlpool LSQ8512KT0
Whirlpool LSQ8520JQ0
Whirlpool LSQ8520JQ1
Whirlpool LSQ8543JQ0
  #2 (permalink)
Old 07-25-2012, 11:30 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Check wire harness and plugs, start cap., motor.
Remove the motor and drain pump and see if the motor will run.
Check if the pump is jammed.
I don't see haw the loose brake water can jam the basket?
Here are the breakdown diagrams and Replacement parts for Whirlpool LSN1000KQ0 WASHER - DIRECT DRIVE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 07-26-2012, 04:17 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
It probably fell in the tub and jamed the basket. Go to my sticky above" replacing direct drive washer brake shoes" for info on this But you will need to buy the special spanner wrench to remove the drive block nut.
__________________
  #4 (permalink)
Old 07-26-2012, 12:51 PM
Junior Member
Default
OK, Ive pulled apart the machine, checked the wiring harness, start capacitor, clutch, everything looks like it is in working order. The only thing I have not tested is the motor. Is there a way to test this using a multimeter somehow? Keep in mind, with the machine assembled, it fills with water, then stops. The timer switch makes noise on any cycle I put the selector to, but nothing happens, won't agitate, won't spin, won't pump. Really would like to diagnose this correctly before I spend needlessly for the incorrect part. Thanks again
  #5 (permalink)
Old 07-27-2012, 01:39 AM
Senior Expert
APP Volunteer
Default
If the washer motor never runs in any mode, either you have a motor thermal cutout that opened, or a bad timer. I would pull the cover off the timer and look for burnt contacts, then check continuity of the motor thermal cutout.
Looks like you can't take the cover off the timer.
__________________
  #6 (permalink)
Old 07-27-2012, 05:50 AM
Junior Member
Default
The timer I believe still works, it will advance thru all the cycles, water fills at the appropriate times, i.e. at the beginning, at the rinse cycles, etc, and the buzzer sounds and the timer still clicks when it hits off, this is what has me thinking its the motor. I will check for continuity and post what I find, thanks
  #7 (permalink)
Old 07-28-2012, 12:57 AM
Member
MayTech is on a distinguished road
Default
I know you said you've checked your lid switch, but i'd double check it and the wire harness connector, also make sure it's being actuated properly.
let us know what you find
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Washer fills with water then stops wilbobluk Washer Repair 4 12-28-2011 05:27 PM
Whirlpool washer starts, fills with water and nothing. whatspoppin Washer Repair 1 10-10-2011 06:19 PM
Whirlpool combo washer cold water fills slow TammyJJ Washer Repair 3 04-26-2011 02:38 PM
Whirlpool Fills with water but nothing else jpkuehle Washer Repair 0 03-18-2009 06:56 PM
kirkland whirlpool washer fills with water but doesnt do anything after filling nikkismp Washer Repair 2 06-28-2008 11:39 AM
