Discuss
Montgomery Ward won't spin/hums
 in
Washer Repair
First there was no spin. I found a relay that was locked (like when you open the door at end
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Montgomery Ward won't spin/hums
  #1 (permalink)
Old 01-27-2008, 05:08 PM
lumstruck lumstruck is offline
Junior Member
lumstruck is on a distinguished road
Default Montgomery Ward won't spin/hums
Model Number: 6322-A8()   Brand: Wards   Age: More than 10 years
First there was no spin. I found a relay that was locked (like when you open the door at end of spin cycle) so I pulled it back with a plastic tie and it spun like normal. Figured I needed another relay but had to do some wash so I loaded it up and with the relay pulled back, it didn't wash properly so I took the tie off and it washed like normal. I manually put it into the spin cycle so I could monitor what was going on and then nothing but a hum. If I pull the relay back, nothing...if I let the relay go, nothing AND now, it won't wash either. All it does is hum like it does between cycles and if I let go on an hum, after about a minute, I suppose a breaker trips in the motor or something and the hum goes away. I let it sit a hour and then tried again...the hum is back but there is no agitation or spin attempted. Any ideas?? Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-28-2008, 01:29 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Sounds like the motor gone bad.
The model number you posted is incorrect or just too old - it does not come up.
Verify and repost it, please.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-30-2008, 07:04 AM
Junior Member
Default
yep, the model is correct and is probably over 15 years old...don't really know, it came with the house I bought over 12 years ago.
The hum is not in the motor but in the selector nob that I suppose sends power to the motor. could the relay that I tied up have crashed the controler knob assembly??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer hums but doesn't start bolinguist Dryer Repair 0 11-22-2007 05:06 PM
Replace Montgomery Wards Dryer Belt mbcorns Dryer Repair 3 10-18-2007 04:43 AM
Hums when start is pressed then does nothing Jacy213 Dryer Repair 3 09-19-2007 06:51 AM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
Maytag Washer just hums spurzem Washer Repair 0 08-22-2007 11:17 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
