| » Washer agitator not working and not draining |
Model Number: SAWX650JQ0 Brand: Whirlpool Age: More than 10 years
Our washer is a Kirklands Signature by Whirlpool. It is not going past the fill cycle. It will not drain or spin. We think it is the agitator or the motor but are unsure. We tried turning our breaker on and off but that does not help.
So when you put it into spin does anything happen? Does it sound like the motor tries to kick on? The unit should drain if the motor runs. It's a direct drive pump. if it's not agitating or spinning but the motor is running then it would be a broken motor coupling, but it should still drain.. If the motor hums for a few seconds and then stops then it's possible you have blockage in the pump (sock/rag/etc.)
If it fills and sits and does nothing at all (no motor noise at all) then it's either the motor, the lid switch or possibly the timer or a wiring issue. I'd still say lid switch, double check it to be sure. |
| Display Modes | |
| Washer agitator not working | dm3 | Washer Repair | 1 | 12-18-2011 07:03 PM |
| Help-My GE washer agitator is not working!! | Jennifer123 | Washer Repair | 4 | 12-14-2011 04:14 PM |
| washer agitator not working | Mane | Washer Repair | 3 | 01-03-2011 08:30 AM |
| Estate Washer Agitator Not Working | blonda1972 | Washer Repair | 3 | 04-06-2009 10:35 PM |
| GE Washer agitator not working, please help my dad! | TiffanyK | Washer Repair | 8 | 09-20-2008 07:35 PM |
