Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Tumbles but no Spin Cycle (http://forum.appliancepartspros.com/washer-repair/491121-tumbles-but-no-spin-cycle.html)
Rob2001 07-23-2012 03:33 PM
Please help! My washer quit spinning on the rinse and spin cycle. The drum tumbles in the rinse cycle normally but when it goes to the drain and spin mode the water drains out but the drum never spins (Motor never turns on)? I found some info online that said if it did not drain fast enough it would not spin and to check the drain cup before the water goes into the pump. I found that it was full of coins and junk cleaned it out and re-connected it to the pump. Ran a full cycle thinking I had it fixed the problem but it still does not spin? It does drain much faster now though. Any help anyone can give me would be greatly appreciated!
Thank You
Rob
Simon / APP Team 07-23-2012 05:43 PM
Hi, Rob.
Most likely you need to replace the door lock assembly.
Part number: 131763202
Here are the breakdown diagrams and Replacement parts for Frigidaire FTFB4000GS0 Frigidaire/washer | AppliancePartsPros.com
Good luck. Post the results.
Simon.
