| » How to install a siphon drain |
i posted the answer on the other post you asked in.
Accessing siphon break for replacement good luck. Edit, just noticed your model is different, the diss-assembly is basically the same, you'll just have to pull the washer out a little ways from the dryer frame. make sure you disconnect power to unit, and you'll probably have to move the pressure switch on the left side to access the screw on the left side. Last edited by MayTech : 07-22-2012 at 01:08 PM. |
| Display Modes | |
| Accessing siphon break for replacement | jgarison | Washer Repair | 2 | 07-22-2012 12:43 PM |
| siphon elbow | fino | Washer Repair | 0 | 10-13-2010 04:51 PM |
| Install drain pan | BarkerDanny | Refrigerator & Freezer Repair | 0 | 09-03-2010 11:43 AM |
| Siphon cup will not fill up all the way, help ! | hdhm | Washer Repair | 1 | 01-31-2010 09:57 AM |
| Anti Siphon Device selection | teague58 | Washer Repair | 7 | 05-07-2009 07:23 PM |
