Discuss
whirlpool washer trouble please help!
 in
Washer Repair
Hi guys I've had a problem with this washer for a while now and need some advice. It fills with
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool washer trouble please help!
  #1 (permalink)
Old 07-21-2012, 06:01 PM
Junior Member
nflguy is on a distinguished road
Default whirlpool washer trouble please help!
Model Number: LSV7245A   Brand: Whirlpool   Age: More than 10 years
Hi guys
I've had a problem with this washer for a while now and need some advice. It fills with water and then stops when the water level is reached, then does nothing after that.
I have checked the lid switch for continuity and its fine. I have pulled the cabinet off and removed the motor to check the drive coupling. The three posts on each piece are intact and the rubber disc between them seems fine also with no rips or tears. I don't see any signs of wear in the coupling (yes even after a dozen years or so).
I am wondering if the timer could be the problem. With the washer plugged in, the timer turns on its own and I can hear the motor hum so would this also rule out the timer? As I said, the motor hums so I think I could rule out the motor also? Is it possible the coupling is bad even though the posts are intact and the rubber disc seems to be fine also?
Thanks in advance for any help or suggestions.
Ads By Google
Related Models
Whirlpool LSV7245AN0
Whirlpool LSV7245AQ0
Whirlpool LSV7245AW0
Whirlpool LSV8244BN0
Whirlpool LSV8244BQ0
Whirlpool LSV8244BW0
Whirlpool LSV8244DQ0
Whirlpool LSV8244DZ0
Whirlpool LSV8245AN0
Whirlpool LSV8245AW0
Whirlpool LSV9244DQ0
Whirlpool LSV9244DZ0
Whirlpool LSV9245BN0
Whirlpool LSV9245BW0
Whirlpool LSV9355AN0
Whirlpool LSV9355AW0
Whirlpool LSV9355BN0
Whirlpool LSV9355BW0
Maytag LSW24A Ref - SXS/I&W
Whirlpool LSW9245EQ0
Whirlpool LSW9245EQ1
Whirlpool LSW9245EQ2
Whirlpool LSW9700PQ0 Automatic Washer
Whirlpool LSW9700PQ1 Automatic Washer
Whirlpool LSW9700PQ2 Automatic Washer
Whirlpool LSW9750PW0 Automatic Washer
Whirlpool LSW9750PW1 Automatic Washer
Whirlpool LSW9750PW2 Automatic Washer
Whirlpool LSW9750PW3 Automatic Washer
Frigidaire LT150EXD2 Wwh(v1) / Tumble Action Washer
Frigidaire LT150EXF2 Wwh(v2) / Tumble Action Washer
Frigidaire LT150EXH2 Wwh(v3) / Tumble Action Washer
Frigidaire LT150EXV2 Wwh(v4) / Tumble Action Washer
Frigidaire LT150EXW2 Wwh(v5) / Tumble Action Washer
Frigidaire LT150JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT150JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT150JXW1 Wwh(v5) / Tumble Action Washer
Frigidaire LT150LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150LXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT200PXD2 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT200PXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXW2 Wwh(v1) / 27 " Front Load Washer
Frigidaire LT250EXD2 Wwh(v6) / Tumble Action Washer
Frigidaire LT250EXD4 Wwh(v7) / Tumble Action Washer
Frigidaire LT250EXF2 Wwh(v8) / Tumble Action Washer
Frigidaire LT250EXF4 Wwh(v9) / Tumble Action Washer
Frigidaire LT250EXH2 Wwh(v10) / Tumble Action Washer
Frigidaire LT250EXH4 Wwh(v11) / Tumble Action Washer
Frigidaire LT250EXV2 Wwh(v12) / Tumble Action Washer
Frigidaire LT250EXV4 Wwh(v13) / Tumble Action Washer
Frigidaire LT250EXW2 Wwh(v14) / Tumble Action Washer
Frigidaire LT250EXW4 Wwh(v15) / Tumble Action Washer
Frigidaire LT250JXD1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250JXF1 Wwh(v7) / Tumble Action Washer
Frigidaire LT250JXH1 Wwh(v8) / Tumble Action Washer
Frigidaire LT250JXV1 Wwh(v9) / Tumble Action Washer
Frigidaire LT250JXW1 Wwh(v10) / Tumble Action Washer
Frigidaire LT250LXD1 Wwh(v5) / Tumble Action Washer
Frigidaire LT250LXH1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250LXW1 Wwh(v4) / Tumble Action Washer
Frigidaire LT350RXD1 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT350RXW1 Wwh(v1) / 27 " Front Load Washer
Whirlpool LT4900XMW0
Whirlpool LT4900XMW1
Whirlpool LT4900XMW2
Whirlpool LT4900XSW1
Whirlpool LT4900XSW2
Whirlpool LT4900XSW3
Whirlpool LT4905XMW0
Whirlpool LT5000XLW0
Whirlpool LT5000XMW0
Whirlpool LT5000XMW1
Whirlpool LT5000XSW1
Whirlpool LT5000XSW2
Whirlpool LT5000XSW3
Whirlpool LT5000XVN0
Whirlpool LT5000XVW0
Whirlpool LT5004XMW0
Whirlpool LT5004XMW1
Whirlpool LT5004XSW1
Whirlpool LT5004XSW2
Whirlpool LT5004XSW3
Whirlpool LT5004XVN0
Whirlpool LT5004XVW0
Whirlpool LT5005XMW0
Whirlpool LT5009XMW0
Whirlpool LT5100XSW0
Whirlpool LT5100XSW1
Whirlpool LT5100XVN0
Whirlpool LT5100XVW0
Frigidaire LT600EXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600EXD4 Wwh(v2) / Tumble Action Washer
Frigidaire LT600EXF1 Wwh(v3) / Tumble Action Washer
Frigidaire LT600EXF4 Wwh(v4) / Tumble Action Washer
Frigidaire LT600EXH1 Wwh(v5) / Tumble Action Washer
Frigidaire LT600EXH4 Wwh(v6) / Tumble Action Washer
Frigidaire LT600EXV1 Wwh(v7) / Tumble Action Washer
Frigidaire LT600EXV4 Wwh(v8) / Tumble Action Washer
Frigidaire LT600EXW1 Wwh(v9) / Tumble Action Washer
Frigidaire LT600EXW4 Wwh(v10) / Tumble Action Washer
Frigidaire LT600JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600JXF1 Wwh(v2) / Tumble Action Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool washer trouble mtthompson Washer Repair 1 06-01-2012 05:58 PM
Trouble with Whirlpool washer! gamebird Oven Repair (including Ranges and Cooktops) 0 08-21-2011 10:44 PM
Whirlpool Washer has trouble spinning thomasc Washer Repair 1 10-25-2010 09:40 AM
whirlpool duet trouble wildfire14032 Washer Repair 1 08-26-2009 12:26 PM
whirlpool washer has trouble spinning ploose@omnek.com Washer Repair 1 03-06-2009 08:11 PM
